Newbie here, needs help please. >
Old 02-05-2011, 08:35 PM
Registered User
Exclamation Newbie here, needs help please.
alright, I'm new to this stuff and I'm planning to get either a savage flux 2350 or the flux hp.
What is the difference?, which one is better?
what is the highest level battery can these things take? whats the recommendations?
and whats the standard battery connector type for both the flux and 2350?
last, what is the recommended charger for it?
andrewmarcelino is offline
Old 02-05-2011, 09:38 PM
T. Herwig's Avatar
Trader Rating: 25 (100%+)
The Flux HP is better I'd say. It uses a 2200kv motor as compared to the 2350kv in the other. You can use up to 6S on the Flux HP and then the 2350 only allows up to 4S I believe. I don't know the standard connectors of the two. I recommend deans or Traxxas however. As for a charger and batteries, I recommend www.hobbyking.com. Lots of cheap chargers and batteries. You would need to run dual batteries in a Savage. Either 2 (2S 7.4) or 2 (3S 11.1) packs.
T. Herwig is offline
Old 02-05-2011, 10:57 PM
Registered User
i forgot one more thing,
I've just realised that the batteries have some kind of rating,
(e.g 20C, 25C, etc) does this matter?
and does the battery need a minimum of 5000mAh?
Old 02-05-2011, 11:05 PM
redthunder's Avatar
Trader Rating: 15 (100%+)
+1
makes electric so much more affordable with their cheap battery's and chargers, same with servos as well
redthunder is offline
Old 02-05-2011, 11:50 PM
Registered User
Does all chargers have wall adapters?
cus they never show pictures of them.
Old 02-06-2011, 12:29 AM
redthunder's Avatar
nup you'll need a power supply to power the charger, like this combo, i have this charger:
http://www.hobbyking.com/hobbyking/s...dProduct=11444
powered by this power supply:
http://www.hobbyking.com/hobbyking/s...dProduct=13765
hope this helps
Old 02-06-2011, 12:54 AM
Registered User
thank you very much for the info.
Old 02-06-2011, 02:21 AM
I recommend the higher c rating I personly only buy 40c ,which means they can discharge a lot better ( more punch when u nail the throttle) with out dropping to much voltage i think for the savage u will want a min of 3000mah,cause the weight of the truck and the size and power of those motors can suck batteries pretty dry Very quick , hope this helps...
evonut is offline
