Tekin RS ESC question >
Old 02-01-2011, 03:50 PM
Default Tekin RS ESC question
Can u run the Tekin 550 can SC4X motors with an RS ESC?
b5975g is offline
Old 02-01-2011, 03:52 PM
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Would not recommend it- unless you want to see it smoke
flame56mx is offline
Old 02-01-2011, 03:55 PM
Briguy's Avatar
Trader Rating: 125 (100%+)
Randy said a RS Pro might handle it but would be running hot and recommended to get the RX8 , which is what I will be using .
Briguy is offline
Old 02-01-2011, 03:56 PM
smokinu's Avatar
Trader Rating: 82 (99%+)
+1.. Even the Rs pro has trouble running them.. with two caps.. and even then you might over heat it.
smokinu is offline
Old 02-01-2011, 04:59 PM
Ok thx How bout running a hyper 10 on an rs with a redlines 5.5?
b5975g is offline
Old 02-01-2011, 05:01 PM
Briguy's Avatar
Nope , RS can`t handle a 5.5 . You would need a RS Pro .
Briguy is offline
Old 02-01-2011, 05:19 PM
Team Tekin
Randy_Pike's Avatar
The RS is only rated for a 5.5 in a 2wd application. 6bl SCT's were not around when the RS line of speedo's were made.
If you want a buller proof 4wd SCT setup get the Rx8 and either the 4.5 or 5.5 Sc4x motor. The current 4wd SCT's are 5.5lbs or more. That maybe 1/10 in size but not weight.
Randy_Pike is offline
Old 02-01-2011, 06:28 PM
Trader Rating: 36 (100%+)
Randy, if I might. Have you any knowledge/experience with the Hyper TT? You think an RS/6.5 will be pushed too hard? I can't compare as I don't have a 4WD SC, but I would imagine it is lighter.... Thx
NitroOB4You is offline
Old 02-01-2011, 06:33 PM
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Please see the Tekin threads, I think there is also a RX8 thread that may be able to assist you. http://www.rctech.net/forum/electric...s-offroad.html
rangerjkb is offline
Old 02-02-2011, 08:11 AM
Team Tekin
Randy_Pike's Avatar
The hyperTT is the same platform as the 4wd SCT Hyper 10. The tires are different yes but you're still hovering over the 4lb mark or more. The 6.5 Redline will be better in this platform but once you've used the Sc4x you'll never go back.
My vote: Rx8 with the Sc4x 4.5.
Old 02-02-2011, 08:38 AM
Thx Ranger...I am aware of that thread, just thought I'd take a stab here :P
Thx for the info Randy. I am currently running the RS/8.5 but wanted to experiment.
Old 02-02-2011, 10:42 AM
Integra's Avatar
Love the new Avatar Randy.
Integra is offline
