2wd Slash slipper clutch question >
Old 01-27-2011, 11:15 AM
trytowin's Avatar
Questions?? 2wd Slash slipper clutch question
Howdy, I have a 2wd slash that I recently converted for racing in open class. Run a 4600kv Castle motor w/ Momba ESC. Having difficulties with the slipper tho, no matter how I set it (tight/loose) it seems to be slipping nearly all the time. To keep the motor temps down I use a 17t pinion and 90t spur combo, is this a good combo? The pads get glazed no matter how the slipper is set. I have the top speed to keep up with everbody else. I've checked into Robinson clutch but the largest gear I've seen with that is a 72tooth spur, is there any others? Any advise would be appreciated, Thanks.
trytowin is offline
Old 01-27-2011, 11:32 AM
I had the same kind of issue. What I did was mildly scrape the clutch pads to get the finish off them before you install. I also run mine w15/90 to keep the heat down; it still gets "warm" though after about 8-10 min.
bowl806 is offline
Old 01-27-2011, 11:56 AM
trytowin's Avatar
Sounds familar, I installed a fan on my motor also. I've tried lightly sanding the pads also, but get the same results.
trytowin is offline
Old 01-27-2011, 01:38 PM
did the fan help? I'm using the Mamba Pro ESC and it already has a fan on it??
bowl806 is offline
Old 01-27-2011, 02:38 PM
trytowin's Avatar
Oh yea!! The fan knocked down the temps about 20-30 degrees!! Purchased an Integy fan and it did the trick. You might have to trim some of the cooling fins to get it to fit under the trans case tho.
trytowin is offline
Old 01-27-2011, 02:45 PM
trytowin's Avatar
Here are some more pics, it's an Integy fan set-up with a "cowling" that I made with 10mil lexan. Both might be available at your LHS, if not I got the fan off ebay.
Attached Thumbnails 2wd Slash slipper clutch question-img_0161.jpg   2wd Slash slipper clutch question-img_0162.jpg   2wd Slash slipper clutch question-img_0164.jpg
trytowin is offline
Old 01-27-2011, 05:37 PM
ta03 tuner's Avatar
Trader Rating: 30 (100%+)
Another option would be to ditch the entire Traxxas slipper and get the STRC layshaft that allows you to use the Associated slipper/spur assembly. A lot more consistent. I also got the STRC motor plate which was another big plus as the heat generated from brushless motors (especially Castle ones) can quickly warp the plastic motor plate; hence stripping your spur. If you're racing Mod, these two things will help.
ta03 tuner is offline
Old 01-27-2011, 08:11 PM
trytowin's Avatar
Thanks, I'll look into that.
trytowin is offline
