sc10 gearing problem >
Old 01-27-2011, 10:45 AM
Boya321's Avatar
Default sc10 gearing problem
i have sc 10 with a 6.5 lrp motor with a havoc pro speed control yes i know to much motor for that truck but i got it from a buddy my other motor got messed but i was wondering on what gear ratio i should use i tried useing the search but nothing came up the motor gets super hot when i run it for about 5mins i am running agin a lrp 6.5 with 87 spur 16 pinon and havoc pro speed control any advice would be greatly apperciated thanks
Boya321 is offline
Old 01-27-2011, 11:33 AM
Driver86's Avatar
I'm thinking you want to go way down on the gearing like maybe a 9 0r 10 tooth pinion. Maybe even go with the 78t spur as well.
Driver86 is offline
Old 01-27-2011, 11:40 AM
TfnG's Avatar
Trader Rating: 27 (100%+)
What is super hot? Do you have a temp gauge?
TfnG is offline
Old 01-27-2011, 11:45 AM
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Also, recommend running the timing block set at -10 degrees setting.
rangerjkb is offline
Old 01-27-2011, 12:19 PM
Boya321's Avatar
yes i have temp gun and the case was at like 210 and also the timing block is set with the standard block it has 4dots on it
Boya321 is offline
Old 01-27-2011, 01:44 PM
TfnG's Avatar
X 2. Was gonna be my next advice also.
TfnG is offline
