are there any hex adapters for sc10? >
Old 01-26-2011, 07:27 PM
teeforb's Avatar
Trader Rating: 94 (100%+)
Default are there any hex adapters for sc10?
I just picked up a used sc10 and i already have hex'ed sc wheels and tires. is there anyway to put hex adapters on the sc10 to use hex wheels?
thx
teeforb is offline
Old 01-26-2011, 07:30 PM
Trader Rating: 45 (100%+)
Proline, but they are for use with the "Pro-Trac" wheels. They have a kit for both the front and rear... Kevin
SlaminRC17 is offline
Old 01-26-2011, 07:31 PM
pfunk66's Avatar
Pro-line has a kit for front and rear 12mm hexes, but they require the 0 offset protrac rims for proper width to keep the wheels tucked under the body. Several other companies make rear hubs and you can also use the blitz front knuckle assembly I beleive.. but again you need the 0 offset rims for proper width.
pfunk66 is offline
Old 01-26-2011, 08:18 PM
teeforb's Avatar
The wheels I have are pro-tek. But i don't wanna spend 40+ bucks to use them
teeforb is offline
Old 01-26-2011, 08:19 PM
I have found the rear hexes off of a slash fit on great and do not cost a lot of money.
Randy
Go Pack Go
ralaco is offline
Old 01-26-2011, 08:26 PM
Trader Rating: 22 (100%+)
Randy
Go Pack Go
+1
xxx123 is offline
Old 01-26-2011, 08:30 PM
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
i use the strc 12mm hexes, with aka cyclone rims its only 2mm wider than stock
ozzy-crawl is offline
Old 01-26-2011, 10:55 PM
henry's Avatar
You could also get the 17mm adaptors from AKA and use the 17mm short-course wheels from DE racing.
henry is offline
