Double sided tape or velcro??? >
Old 01-27-2011, 03:42 AM
  #16
wallot's Avatar
I use 3M dual lock for everything. Thanks to its thickness works as cushion for receivers and ESCs
wallot is offline
Old 01-27-2011, 05:47 AM
  #17
???E-Racer's Avatar
Originally Posted by drummin89 View Post
I use 3M mounting squares. They are 1" by 1" squares. Hold really well.
I got some of those.
???E-Racer is offline
Old 01-27-2011, 09:17 AM
  #18
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by MO Matrix 01 View Post
I use the Novak servo tape (pretty much re-badged 3M). I just clean up the areas I'm using the tape on with an alcohol wipe and stick the stuff on. It's super strong and if you need to remove something, it'll come off without ripping and leaving a mess behind.
It's what I use, pretty much the same a Parma. It can be tough to find on the roll though. I paid $25 for a roll on e-bay, spendy but it's also 45 feet!
racer1812 is offline
Old 01-27-2011, 09:31 AM
  #19
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
foam tape always peels badly. BRP (or Bud's if ur old like me) is the best stuff for servo tape IMO. however, i'm moving some of my stuff over to velcro to give it quick removal and some 'looseness' for hard hits. seen some elecs fail due to hard hits. there is also some stuff out there that has double side stick but also a gel pad in between that u prolly find alot in $$$ helis. seen them in the store and look like a wise option for some applications.
R
UltegraSTI is offline
Old 01-27-2011, 09:36 AM
  #20
dont even waist your time with tape shoe goo ftw. holds tight and comes off clean every car i have's electronics are shoe gooed in.
slowslug is offline
Old 01-27-2011, 10:06 AM
  #21
1Fastpede's Avatar
Trader Rating: 52 (100%+)
haha
1Fastpede is offline
