1/8 ebuggy run times?
The best I've seen was nearly 20 min in race conditions. I do not recall the type/capacity of battery used.
Buggy: Caster Fusion Pro ( EX1R )
Motor: Tekin 2050
ESC: Hobbywing 80A ( Punch=3, 0 timing)
Batteries: 2 2s 5200mah (4 cells total)
Gearing: 14/44
Run time: 15+ min on a big 1/8th out door track.
RTR weight: not exactly sure
Motor: Tekin 2050
Gearing: 14/44
still trying to figure out what streached is Damn you spell check
Buggy: OFNA Nexx8
Motor: NeuCastle 1512 1.5Y 1800kV
ESC: MMM default settings, with LVC set to 3.5 per cell
Battery: 2 x 2S ProTek 50C 5600mAh
Gearing: 14/46
Run time: 25+ minutes on small 90' straight indoor track
RTR weight: Stock weight 3640g w/tires...havent weighed since option aluminum parts were added
Gearing: 14/46
Buggy: Mugen MBX6 converted
Motor: Hacker C50XL (1350kv)
ESC: XeRun 150A
Batteries: 6S 3200mah Hyperion
Gearing: 17/46
Run time: 15+ min on a medium 1/8th outdoor track
ESC: XeRun 150A
Gearing: 17/46
Xray 808 (not 808e)
Front diff: 41T
Rear diff: 43T
Center ratio: 20/42
Tekin RX8 and 2050kv
Pretty much stock ESC settings, for lack of a HotWire
Turnigy nano-tech 3S 6000mAh 25C
Car weight: 7.6 lb
Track: Indy RC World, Garland, TX. Mid-sized, medium-bite, hard-packed clay
Run time: For 10-minute qualifiers (+1 minute for warm-up), I would run 100% throttle EPA, and afterward would put 4050-4100mAh back into my pack. For a 15-minute main, I turned my EPA down to 80% and smoothed out my driving (which made the car MUCH easier to drive consistently, and still provided equally-fast lap times) and was able to make the 15 minutes.
Front diff: 41T
Rear diff: 43T
Center ratio: 20/42
Car weight: 7.6 lb
Car: Hot Bodies VE8 w/kit setup
ESC: Tekin RX8 - Current Limiter 80%
Motor: Tekin T8 1900kv
Batteries: 2x Protek 5000 35c 2S Lipo
Pinion: 20t
If I don't push hard, I can squeak 20 mins out, but under hard race conditions I get about 15 - then again I drive much harder than most with regards to throttle.
Pinion: 20t
