Like Tree9Likes
Old 07-18-2011, 10:35 PM
  #14866
liftedcj7on44s's Avatar
Originally Posted by Mr.juarez
and less parts that you wont find when you lose them at the track im sure you got a great deal
Thanks for letting me get the jump on them.
liftedcj7on44s is offline
  #14867
Ridley's Avatar
Originally Posted by SaladFork
You can cut that lip off, but it doesn't change the offset since the pin is still in the same spot. Knowing Josh, he cut that off to save weight.
LOL
I use the traxxas hexes. When used with the ten-t axle stubs, you need to shave that ring flat on the back of the hex to get the drive pin to align correctly. Then I reformed the ring by shaving the back of the hex. If it's not reformed, the rear of the hex will drag on the bearing face and plastic carrier, and do so even worse when there's some dirt. This method retains legal width. I also like using the ten-t stubs because you can then cut the end off and counter drill them to save even more weight, so I will likely continue to use these.
I'm unsure what to use with the scte axle stubs, or the 810 axle stubs. If I was building a buggy, I'd just use the 810 stubs and hexes. Legal Buggy specs are wider than sct specs.
I use the DE 17mm sct wheels. They are quite a bit stiffer than the regular DE wheels with 12mm hexes. I had no idea how flexable the 12mm versions were till my buddy showed me a set.......kinda scary. The 17mm version is substantially more stout. Still very slightly more flexable than a proline wheel....but not gumby style like their others.
Ridley is offline
Old 07-18-2011, 10:37 PM
  #14868
Calling it a night tonight guys.
If I sit here and keep on listening to Mark Knopfler tonight I will never get to sleep.
Old 07-18-2011, 10:44 PM
  #14869
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
no problem.
past curfew huh?
Mr.juarez is offline
Old 07-18-2011, 11:20 PM
  #14870
10sctrel0v3r's Avatar
rebuilt my front diff earlier tonight...ran it up the street in the dark then noticed a cat was chasing it...quick flick of the e-brake made him change his mind
10sctrel0v3r is offline
Old 07-19-2011, 12:29 AM
  #14871
Cult Racing's Avatar
Trader Rating: 42 (100%+)
wish i saw that!
Cult Racing is offline
Old 07-19-2011, 12:38 AM
  #14872
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
so i reported that when i finished my conversion from ten-t to SCTE, i weighed the truck and got 6.5 pounds. this was on a friend's scale. i bought a cheapie food scale off fleabay and it came today. i threw the truck on it and it showed 6.75 pounds! she's a fat bish. so i put the losi diff riser in (had the rc-monster which is aluminum) and hacked a bit off the battery tray (again rc-monster which seems thicker than the losi tray). got her down to 6.68 pounds. only lightening plans in the future are CF towers and hinge pin holders. after that, i may have to go with a new chassis.
i don't want/need to get under 6 pounds, but i'd like to get at least a bit closer to the 6 pound mark (maybe 6.2 or 6.3).
i may throw her on the scale with another body. my current body has a bunch of gorilla tape on it...
RC*PHREAK is offline
Old 07-19-2011, 12:48 AM
  #14873
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
I am getting ready to finish with the CF chassis for this truck any suggestion before I start milling.
SNR Graphite is offline
Old 07-19-2011, 12:58 AM
  #14874
RC*PHREAK's Avatar
yes, send me the completed chassis for testing!
seriously though, i think you guys have been around the block long enough times that i would trust your skills before any suggestion i might have. i guess i can only offer the old adage: measure twice, cut once! haha.
Old 07-19-2011, 01:37 AM
  #14875
SaladFork's Avatar
Originally Posted by Ridley
LOL
I gotcha, I thought they wanted to run the buggy wheels. Funny we just swapped my Ten T axles on Saturday... I hated to swap but we have to many sets of the stock size, it made sense to move over. They lasted that's all that mattered.
Ran the DE wheels this weekend and you are not kidding, might be light but they are really flexible.
Keep up the good work man!
SaladFork is offline
Old 07-19-2011, 04:10 AM
  #14876
jmc23's Avatar
Default novak
Originally Posted by CHIZZLE
If anybody wants to sell their 14mm Novak rotor let me know. Apparently they won't be selling them anymore but I'd really like to try one out.
I haven't had much luck with the novak 4.5 550 set up . temps for one. installed 14mm rotor when I first. got it. it took out the whole motor. sent it in for repair. in mean time was running 1410 combo. so I decided to try the novak again after I put my truck on a diet.6 lbs with novak combo in geared 17-40 spun rotor off shaft after 2 races. not happy. mailed novak and they no longer have 14mm rotor in stock so the said to send it in and they will repair it. I'm sure that will be a month or so. Look into some other options . the 1410 is a great motor. and I hear tekin has a 4 pole on the way.....
jmc23 is offline
Old 07-19-2011, 05:38 AM
  #14877
wow im sorry to hear your bad luck with novak. i hope everything goes smoothly with my 14mm that i just installed. i gotta go get pinnions now. 14t wont cut it
Old 07-19-2011, 06:13 AM
  #14878
im running up to my LHS later on today and im wondering what other battery trays have people modded to put in this truck?
  #14879
CHIZZLE's Avatar
Originally Posted by losi_racer
Doug, I think your best best is to just try. Start with the 15t and your current limit turned downed and go up if you can. Hard question for anybody to answer, really.
CHIZZLE is offline
Old 07-19-2011, 06:21 AM
  #14880
CHIZZLE's Avatar
I'm sorry to hear that. I have all kinds of Novak stuff and have had pretty decent luck with them. With my Jammin I put a 13t on and never even looked at the temps. But with this thing I'm constantly monitoring. Right now, I'm running the regular 4.5 Ballistic. I want to try the 14mm rotor and also, maybe the 5.5 motor.
CHIZZLE is offline
