Like Tree9Likes
Old 07-18-2011, 09:08 PM
  #14851
liftedcj7on44s's Avatar
Originally Posted by RC*PHREAK
i have that same set up from when my rig was a ten-t. don't really have much need for it now.........
Send them my way! LOL
To the guy asking about the MMP and the 1410. It has been beaten to death in this thread. Most people run that setup(well a lot of them including myself).
I personally run a 15T pinion.
liftedcj7on44s is offline
Old 07-18-2011, 09:10 PM
  #14852
Originally Posted by SaladFork
You can cut that lip off, but it doesn't change the offset since the pin is still in the same spot. Knowing Josh, he cut that off to save weight.
Hmmm, I am no rocket scientist or an engineer but if you cut that lip off then the outer bearing will come out of the spindle.
Old 07-18-2011, 09:21 PM
  #14853
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by lowroad
no, no one.
lmfao!!!!
+ YouTube Video
no it wont. you dont cut it flush but you leave that tiny little small lip for the bearing to sit on
Mr.juarez is offline
  #14854
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
what you got to trade?
M2C 17mm adapters go for 30 and i don't know what the ten-t axles go for. let's work a little trade. doesn't even have to be equal value. like some spare parts for the SCTE? i dunno.
RC*PHREAK is offline
Old 07-18-2011, 09:25 PM
  #14855
Mr.juarez's Avatar
if lifted doesnt take them i may have some things to trade you for them. like new 1 day used strc towers in blue, set of shock parts losb294, strc shock collars.
Old 07-18-2011, 09:32 PM
  #14856
I got new A-arms front and rear.
Old 07-18-2011, 09:46 PM
  #14857
RC*PHREAK's Avatar
done. mr. juarez is an honest chap and deferred to you. let's take it to PM's for details.
Old 07-18-2011, 09:47 PM
  #14858
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by losi_racer
question since were on the whole run time/heat thing here : )
Im running 5.5, RX8, stock settings on the esc. I was running a 16T Pinion, i was running 180 then one night it went to 200, had to drop to a 15T now im at 155. Since then ive already tore the truck apart no binding, mesh is fine, also run time isnt an issue on either pinion. IF i drop my CL down to 80-85, this will limit the amp draw and cool the motor, so would i be able to go back up to my 16 then and my temps should be 160-170 range? I liked it better as ive lost my top end with the 15 but its not terrible. also btw im in az where its 100-105 at night when we race
losi_racer is offline
Old 07-18-2011, 10:03 PM
  #14859
timannnn6's Avatar
Trader Rating: 140 (100%+)
Originally Posted by BlackLabelVinyl
Hey guys, I just started making these for the Losi. Let me know if you're interested.
http://www.rctech.net/forum/r-c-item...4x4-1-8-a.html
You can get a 8 inch by 10 foot roll of 15mil for $13.99 shipped on fleabay.
http://cgi.ebay.com/ebaymotors/1-rol...#ht_500wt_1124
timannnn6 is offline
Old 07-18-2011, 10:05 PM
  #14860
Mr.juarez's Avatar
wow! that was a low blow
Old 07-18-2011, 10:10 PM
  #14861
I agree.
Old 07-18-2011, 10:22 PM
  #14862
Trader Rating: 19 (100%+)
Default Wheel Adapters!!!
Wheel Adapters...
Anything made for or used on the Ten-T or even the 810 is NOT going to work, including the Traxxas adapters for the Maxx series UNLESS you convert to the respective stub axles, either the Ten-T axles that are "0 offset" or the wider 810 axles.
The main reason is the Ten-T and 810 axle "shoulders" that support the hex's are 6mm and the through pin is larger that the SCTE's 5mm axle and pin.
What will work if you want to keep the SCTE's stock axle and pin is anything that was made for the rear on all the other sct's on the market already to convert to 17mm, although some have more offset than others.
These look perfect though if you dont want to alter the offset, although you might actually end up a little narrower than stock if using a flat faced buggy wheel.
http://www.amainhobbies.com/product_...dapters-Rear-2
The ones for the Slash 4x4 by AKA look pretty good too and should be close to 0 offset considering on the Slash 4x4 they are intended to keep the "stock" offset, although you probably will end up slightly wider...
http://www.amainhobbies.com/product_...s-Complete-Kit
I'm sure the will be specific SCTE one's on the market soon enough...
shenri is offline
Old 07-18-2011, 10:30 PM
  #14863
Pretty sure that is why the one's that I am going to get from RC Phreak will include the Ten T stub axle.
Old 07-18-2011, 10:32 PM
  #14864
RC*PHREAK's Avatar
stub axles, and the larger pins (which you can see in the pictures that are in the adapters).
Old 07-18-2011, 10:33 PM
  #14865
Mr.juarez's Avatar
and less parts that you wont find when you lose them at the track im sure you got a great deal
