Like Tree9Likes
Old 07-18-2011, 07:27 PM
  #14836
SaladFork's Avatar
Originally Posted by liftedcj7on44s
LOL, you just asked 2 of the questions that I would like to know as well.
After taking off the bumpers and some other stuff the other day I got to thinking I might try mine as a buggy as it should handle a lot better and run a lot longer.
I would also like to know which adapter's would fit so I could run buggy tires when I am at home bashing because on 3s it seems that a good buggy tire will hold up better.
As far as shock tower's I just ordered the 4mm Carbon towers that are posted on the first page in this thread.
Just get the 810 axles, axle nuts and hubs... Then you can run 17mm wheels. They bolt right on.
SaladFork is offline
Old 07-18-2011, 07:30 PM
  #14837
losi_racer's Avatar
Trader Rating: 25 (100%+)
question since were on the whole run time/heat thing here : )
Im running 5.5, RX8, stock settings on the esc. I was running a 16T Pinion, i was running 180 then one night it went to 200, had to drop to a 15T now im at 155. Since then ive already tore the truck apart no binding, mesh is fine, also run time isnt an issue on either pinion. IF i drop my CL down to 80-85, this will limit the amp draw and cool the motor, so would i be able to go back up to my 16 then and my temps should be 160-170 range? I liked it better as ive lost my top end with the 15 but its not terrible. also btw im in az where its 100-105 at night when we race
losi_racer is offline
Old 07-18-2011, 07:58 PM
  #14838
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by jasonwipf
Ok I got a couple questions.
Who makes the best carbon shock towers for this car?
losi and snr, i got the snr and they're are great
Has anyone here converted it to a buggy, if so did you like it?
yes i have and it handles so much better
i bought the 810 hexes they are different than a regular 17mm hex. its actually cheaper if you just buyt he m2c 17mm adapter for like 25 i think
is there any adapter to use 1/8th buggy 17mm wheels to fit?
if i remembered right you asked the same questions couple of pages back and i replied to them, which i dont think you even checked
right, but dont they make it wayyyy wider?
this is a traxxas 17mm hexes but the losi 17mm are the same. only the 810 have that spacer thing in the back or whatever you want to call it. I think josh or someone else cut that off flush
Mr.juarez is offline
Old 07-18-2011, 08:11 PM
  #14839
liftedcj7on44s's Avatar
So exactly which adapter should we get that will bolt right on to the stock SCTE stub axle and allow buggy wheels.
I personally absolutely cannot stand the stock Rims or the beadlocks. I also cannot stand the DE wheels either.
I will run the stock wheels on the track but not at home.
liftedcj7on44s is offline
Old 07-18-2011, 08:22 PM
  #14840
Mr.juarez's Avatar
this is straight from chris atterberry pm i got
I'm using the M2C 17mm hub adapters on my TEN-T E conversion:
http://www.m2cracing.com/product.sc?...ryId=49I'm using the M2C 17mm hub adapters on my TEN-T E conversion.
i dont know why the link dont work anymore but i think this may be it
http://www.m2cracing.com/product.sc;...&categoryId=-1
double check with chris to see if they're the same part number to his adapters before you buy them
i dont have an issue with the bead lock look or the de one, the only issue i have is their stupid 50-70 dollar for a full set when i can get pre mount panther tires for 28 shipped
Old 07-18-2011, 08:24 PM
  #14841
Look's as if those use set screws to hold the adapter on, Wonder how long they would last as I have always had trouble with that particular setup on other vehicles.
Old 07-18-2011, 08:36 PM
  #14842
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
So whats the best to use with a 550, 4.5 turbo boost, or timing on the esc?
Blitzrockey is offline
Old 07-18-2011, 08:52 PM
  #14843
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
I don't use any turbo, boost, timing advance, etc on my 4.5 with my RX8. I actually turn it down by running the current limiter at 75-80%.
heavyjeffd is offline
Old 07-18-2011, 08:58 PM
  #14844
Mr.juarez's Avatar
then you must not be using locktite
this is what chris is using
http://www.rctech.net/forum/r-c-item...en-t-scte.html
Old 07-18-2011, 09:01 PM
  #14845
Trader Rating: 30 (100%+)
Anyone running a Mamba max pro and 1410 motor in this truck? How well does this combo work and what is a good pinion gear for med size track? Any tips on this combo? Whats the runtime on 5000mah 40c?
Jay13 is offline
Old 07-18-2011, 09:05 PM
  #14846
Im using a sp gt 2.0 awsome esc, only ever gets to about 80 degrees. I run about 12 degrees of timing, and the motor is about 145 and rips good. Was thinking of trying turbo boost instead just for the top end more so. Hmmm.
  #14847
lowroad's Avatar
Trader Rating: 79 (100%+)
no, no one.
lowroad is offline
Old 07-18-2011, 09:06 PM
  #14848
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
i have that same set up from when my rig was a ten-t. don't really have much need for it now.........
RC*PHREAK is offline
  #14849
Trader Rating: 46 (98%+)
at our race this weekend, my buddy and i went through 4 motors and 2 speed controls. the only thing to survive was the mmp and 1410 on his. i believe he ended up with a 15 or 16 pinion. that battery should get you 7-9 min of runtime. all depends on track style and trigger finger. lol
nitroal is offline
Old 07-18-2011, 09:08 PM
  #14850
SaladFork's Avatar
You can cut that lip off, but it doesn't change the offset since the pin is still in the same spot. Knowing Josh, he cut that off to save weight.
