Like Tree9Likes
Old 07-18-2011, 10:49 AM
  #14791
crip#8's Avatar
Default diffs
I'm sure its been said but what diff fluids are people running for outdoor 1/8 scale track Med traction thanks in advance
crip#8 is offline
Old 07-18-2011, 10:54 AM
  #14792
Trader Rating: 46 (98%+)
Originally Posted by ScottKelly911 View Post
now just need the pix for the RC8 rear chassis brace
the rc8 chassis brace just uses the motor mount hole that is unused. lines up perfect!!
nitroal is offline
Old 07-18-2011, 10:55 AM
  #14793
i've been running 5,3,2 and it seems pretty good.
nitroal is offline
Old 07-18-2011, 11:16 AM
  #14794
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
5,7,2 or 5,5,2
ChrisAttebery is offline
Old 07-18-2011, 11:43 AM
  #14795
Buzz3's Avatar
Originally Posted by ChrisAttebery View Post
I've been running one for a couple months and really like it. What gear ratio did you run? I'm at 18/40 or 19/40. I don't find the brake effect to be as bad as the 1410 was.
Yeah, the 14mm rotor sucks so bad that only the team drivers can win with it.
I have the brakes backed off quite a bit and I can still nose it over if I come into some corners too hot, but never off throttle. Mine runs great and I can pull most others I have raced down the striaghts.
Buzz3 is offline
Old 07-18-2011, 11:45 AM
  #14796
Jstall7543's Avatar
I was running a 16t pinion. Maybe I'll try it again with a 18t, the temps were under 120 on esc and motor after a full 5600mah 60c pack. But man it was whipping the rear completely sideways on a couple turns. It was ok on the tight corners, like running a rear brake bias, with servo brakes.
Jstall7543 is offline
Old 07-18-2011, 11:53 AM
  #14797
The first couple times I used the new rotor I managed to do a forward roll on braking, land on the wheels and keep going.
Old 07-18-2011, 11:56 AM
  #14798
WAY undergeared my friend. Try 18 or 19 and see how you like it. I beat a couple better drivers (one is an ex pro) at our last race. he commented that in the infield he would catch up, but then every time we got on the straight I pulled 10-15 feet on him.
Set your ESC to dual mode, 50% timing, 50% brake, 85% current limit.
Old 07-18-2011, 11:58 AM
  #14799
Trader Rating: 29 (100%+)
Will Slash wheels fit this truck? I searched but didn't see an answer. Im sure its been covered but I didn't see it. I am looking into buying an SCTE but hat to have to buy all new tires.
Jay13 is offline
Old 07-18-2011, 12:11 PM
  #14800
Casper's Avatar
Trader Rating: 34 (100%+)
Yeah you have to gear the motor way up with the 14mm rotor. I does not start moving until you get in the 18tooth range.
Casper is offline
Old 07-18-2011, 12:26 PM
  #14801
Buzz3's Avatar
You have to love it when someone comes into the thread with little to no knowledge or research on a subject and starts telling everyone else how bad it is. Where's the hand clap smiley?
Buzz3 is offline
Old 07-18-2011, 12:34 PM
  #14802
Moogumby's Avatar
Trader Rating: 32 (100%+)
if your just bashing, they will fit.
if your racing they will stick out from under the body.
Moogumby is offline
Old 07-18-2011, 12:45 PM
  #14803
mharmer's Avatar
Default novak havok pro sc setting
guys i raced this weekend and only made it 9 minutes in a 10 minute main.i was geared at 16/40 . i have a 6000mah battery 60c 4.5 with 14mm rotor. track is medium sized and was high traction . i am hoping to find ot what settings i can change to help me get a little more run time out of it. i took all the timing out of it and drag break is there anything else i should change
mharmer is offline
Old 07-18-2011, 12:54 PM
  #14804
Buzz3's Avatar
You must go up a tooth or three with the 14mm rotor. I run an 18 and my truck is rarely pulled down the straights. I run the nanotech 6000mah 25-50c and I get 10 minutes but not much more. You may find you can dial out some trigger when going up on the gears and that will help with heat and runtimes. I haven't tried the 19 as I don't need the speed at this time and I don't want more heat.
Buzz3 is offline
Old 07-18-2011, 01:20 PM
  #14805
Lenman73's Avatar
How many hot laps are you taking? If there is 2 minutes or whatever between races are you doing a few laps b4 the race starts? If so you could scrape some time from there.
Lenman73 is offline
