Like Tree9Likes
Old 07-11-2011, 01:06 PM
  #14326
RACETEK's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Asharus View Post
Wow, do you guys have any indoor tracks down south? I guess there's no need because you can race outdoors year round. I think I would pass out on the driver's stand if it was 118 out there.
Yea we have a couple in DFW. Indy RC World in Garland and Mike's Hobby Shop in Carrollton. Mike's is hosting one of the Live R/C Crew's Short Course Showdowns in September.
RACETEK is offline
Old 07-11-2011, 01:09 PM
  #14327
mo
mo's Avatar
Originally Posted by Matt Howard View Post
I don't want to brag but I'm 4 for 4 for wins with my SC10 4x4
You need to come back to Cali for your whoopin'.
mo is offline
Old 07-11-2011, 01:11 PM
  #14328
losi_racer's Avatar
Trader Rating: 25 (100%+)
Lmfao ,we have one indoor track n Tucson but its 2 hrs from phx
losi_racer is offline
Old 07-11-2011, 01:13 PM
  #14329
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Randy_Pike View Post
Semple, if you need to make 10 minutes you'll need a bigger battery mah rating. Try 6000mah or more.
5200 won't get it done for 10 minutes.
A lot depends on the track and your throttle finger too.. but yes 5000-5400 range is not likely for any setup to make a full 10minutes on a decent size track. Even my 1410 would hit LVC around 9 minutes w/ a 5400mAH pack. I've been using the IP 6200's and the carbon 6500 with out issue.. the carbon holds voltage better though, more rear longer in the race than any of my other packs. I was going to try a crc pack as they are rated top notch and cheaper than the carbons, but I need to stop spending money.. LOL
PS if anyone wants a new chassis to mess around with or as a replacement I have one on ebay for a good price ;P
8ight-e is offline
  #14330
I run a3800 kv 4 pole motor and have noticed the higher the C rating the cooler the motor runs. I have a 60c and a 150c max amps. battery with a16 th pinion and reach temps, between 140 and 150 after a ten minute main. every time i run a 40c geens temps go to 170 -180 and i cant make a ten minute main. I have also ran a 15 th. pinion and temps drop about 5 to 10 degrees. temps stay about the same on any size track.
rldslick is offline
Old 07-11-2011, 01:16 PM
  #14331
hubb0643's Avatar
Default scte diffs
hi guys was just wondering if anyone has an extra frot diff they would be willing to sell. if so pm me
hubb0643 is offline
Old 07-11-2011, 01:29 PM
  #14332
freefallmarine's Avatar
Hey Guy's, I pick up my truck tommorow, and was wondering if there's a sticker or something on the box that say's "updated" or something that say's pin's are taken care of?
freefallmarine is offline
Old 07-11-2011, 01:30 PM
  #14333
Wes, I need a good set up for Mikes! Thank's!
Old 07-11-2011, 01:33 PM
  #14334
bico1's Avatar
Trader Rating: 71 (100%+)
Originally Posted by bico1 View Post
Hey guys,
Recently, I rebuilt my diffs replacing the diff pins with chris pins, cleaned out the factory grease, and re-filled the diffs with the silicon oil (3-3-2). When I took my scte out to drive for the first time after the diff rebuild, I experienced some really weird things. What I noticed first was that the car pulled a little to the right (or left? can't remember exactly) under accelaration and spun out to the right under breaking. Upon closer inspection, the only thing I could find wrong was that the right outdrive of the rear diff was wobbly. Could this be my problem? I took the diff out and confirmed that I had rebuilt it correctly and that all parts/shims/washers/seals were in place. Is the metal holder that the outdrive fits into worn out? Is there something else in addition to this that might be causing my problem?
Anyone take a shot at answer this for me? Thanks fellas!
bico1 is offline
Old 07-11-2011, 01:34 PM
  #14335
RACETEK's Avatar
Indoor I assume?
Shoot me an email and I'll get ya what I can. If it is the big outdoor track I ca do that too.
RACETEK is offline
Old 07-11-2011, 01:35 PM
  #14336
Matt Howard's Avatar
I wish I could Mo, I would I could
Matt Howard is offline
Old 07-11-2011, 01:37 PM
  #14337
Asharus's Avatar
Trader Rating: 42 (100%+)
Battery tray sticker. One A in the end for 2nd shipment, double A for 3rd shipment.
Asharus is offline
Old 07-11-2011, 01:38 PM
  #14338
RACETEK's Avatar
I'll be rocking the SC10 4x4 this weekend but I might have something new to try after that
The Losi I have pictures of in this thread with the body off and all the carbon will be for sale very very soon.. The mod list is very long. So if your interested in a buy it and race it Losi SCTE let me know. If anybody else would like to make an offer shoot an email to me at [email protected]
RACETEK is offline
Old 07-11-2011, 01:55 PM
  #14339
Thanks for the tips, guys. I'll definitely have to get a higher capacity pack. Probably from CRC.
Semple is offline
Old 07-11-2011, 02:10 PM
  #14340
I'm surprised you guys are having trouble making time with the 1410. My track is just stupidly large with elevation changes and big 1/8 scale jumps. The average sportsman type guys are making up to and over a minute a lap. My best times are around 50 seconds flat but we run ten minute mains and it is very very hot here. So far I have yet to put in more than about 4000 mAh into my 6000 mAh battery after a main and no hint of hitting the lvc.
Maybe I'm lucky but it just hasn't been a problem so far. The time I thought it would be was when we had a deluge the night before and the track was muddy and sticky, but I still made time without a problem. I don't take warm up laps prior to the mains just to be sure, but knock on wood, I haven't had an issue so far.
Just seems to me that something is causing drag or your gearing is wrong or something. I run 16/40 on that track, going down to 14/40 on tighter tracks that are still pretty big and set up for 1/8 scales. I do have a bit of timing on my hobbywing ESC because I decided to just run it at the default timing which IIRC is around nine or thirteen degrees or something like that. Is that the difference? I don't know but something just seems wrong here.
chiro972 is offline
