Like Tree9Likes
Old 07-07-2011, 12:36 PM
  #13996
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Cackswayn View Post
Just got an email back from RRP
Good job
Ok guys we will work on it,
Thanks RRP
Same here
Asharus is offline
Old 07-07-2011, 12:40 PM
  #13997
larlev's Avatar
I did also...
larlev is offline
Old 07-07-2011, 12:43 PM
  #13998
SaladFork's Avatar
ditto...
Ok Trey
we are ordering up the model today
it will take a little time but we are going to do something about the problem,
Keep in touch
Thanks RRP
SaladFork is offline
Old 07-07-2011, 12:45 PM
  #13999
Asharus's Avatar
Originally Posted by SaladFork View Post
ditto...
Wow, that's excellent news
Asharus is offline
Old 07-07-2011, 12:51 PM
  #14000
SaladFork's Avatar
Yea!! Everyone needs to buy Scott a beer (or two).
And on more awesome news congrats on hitting 14,000 post!
Old 07-07-2011, 12:59 PM
  #14001
Integra's Avatar
I switched everything to flat head... In a pinch I can use my good friend, butter knife.
Integra is offline
Old 07-07-2011, 01:24 PM
  #14002
BmainStar's Avatar
Originally Posted by heavyjeffd View Post
I tried to explain my displeasure for SAE hardware in this thread when I first got the truck, it was met with lots of "lol yer gay" and "stop crying" replies.
Some people just don't get it.
Or Care! LOL
BmainStar is offline
Old 07-07-2011, 01:26 PM
  #14003
BmainStar's Avatar
Good job
Thanks RRP
For the Love of Mustard Bobby, they are gonna get rich!!
Old 07-07-2011, 01:28 PM
  #14004
Asharus's Avatar
Wow, that's an astronomical amount of posts in this thread, I didn't even realize it. My other threads have maybe 2k posts at the most.
Asharus is offline
Old 07-07-2011, 02:10 PM
  #14005
Question for anyone running the 1410 with the Castle motor fan. Roughly how much in a drop of temp can I expect running the fan? Is there a drop at all in run time? After an 8 minute main my motor temp was 190. Track temp was around 90. I put 4000 mah back into a 5000 pack. I could gear down from 16 to 15 but I like the speed of the 16. Any ideas?
Mototech is offline
Old 07-07-2011, 02:52 PM
  #14006
R/C Tech Elite Member
JayL's Avatar
Originally Posted by Asharus View Post
I have no complaints, my other 2 vehicles are SAE
The only thing I didn't like about the screws on this truck is that my tools did not fit them perfectly as they did in my AE cars. I replaced the screws with Tony's screws and the problem was solved. Not sure if anyone else had the problem but some of the hexes on the screws are too tight? I'm not using welfare tools either, they're pretty decent:
http://teamassociated.com/factorytea.../details/1655/
you need to use this:
http://www.losi.com/Products/Feature...odId=LOSA99130
your truck knows.....
JayL is offline
Old 07-07-2011, 03:50 PM
  #14007
Asharus's Avatar
ROFL, maybe it does! Actually when I was shopping for a hex set it was a toss-up between those two. They're identical, but I happened to have only AE cars at the time so I figured I'd match it up. Plus the blue handle is better looking
Asharus is offline
Old 07-07-2011, 03:55 PM
  #14008
losi_racer's Avatar
Trader Rating: 25 (100%+)
Sweet cracker sandwich!
ROFLMFAO HA HA HA HA
i think im the only one but ill buy the RR gears when they come out
losi_racer is offline
Old 07-07-2011, 04:12 PM
  #14009
Chris K's Avatar
Trader Rating: 46 (100%+)
I run a fan on mine - not at all sure that it's necessary but it makes ME feel better. And my motor has never been hot enough to warrant me dragging out the temp gun! I just figure that any time you're dissipating heat which should more than offset the slight battery drain of these little bitty fans.
AND, it sounds like you're on the HORNS OF A DELIMMA - I'd guess that you're a bit over-geared OR you have something dragging in the drive train. My similar set up - 1410 with MMP was barely warm to the touch after 10 minutes on 15 x 40 - LARGE outdoor 1/8th scale style track that didn't really have a very long straight. And, honestly unless it's a medium to small indoor facility I'd be looking for binding or a bad bearing or 3 because based on the experience of others and myself on this thread you shouldn't be really over geared unless you're on a small track.
Let us know what you decide to do!!!
Chris K is offline
Old 07-07-2011, 05:05 PM
  #14010
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
ever since i got this truck im over heating constantly. fresh diffs 5-5-3 . im running tenshock 4600 (maybe to much) with my heat issues im thinking 3800 to 4000 would be good enough. checked all my cvd pins, two had come out so i contact cemented them in. my pinion set screw was rubbing on the motor mount , so i out right drilled the hole in the motor mount larger. running 43 teeth spur and tried 11 to 13 pinion and getting in the 190's to 206 on the motor. good thing i only payed 60 for the motor or id be severly worried lol but the thing has hit 200 a hand full of time but keeps on ticking.i just installed a lrp fan and atached it to the center diff top plate over the motor it has dropped my temp by about 15. i do have alloy towers but have cut the esc tray off and drilled the battery holder out and yanked the side guards off. just cant get a handle on the heat probs,its never fun to drive when your always worried of temps.
BDRMBULLY is offline
