Like Tree9Likes
Old 07-03-2011, 04:44 PM
  #13501
Originally Posted by Jstall7543 View Post
The snr carbon towers are holding up great on mine, 16 batteries on them on indoor clay, plenty of crashes! Ya, if the body isn't going on right then you bent the tower. Bend it back, order carbon!
I bash only, 40 plus packs through my truck. Many big air roof landings. Losi carbon is holding up great.
LRPO is offline
Old 07-03-2011, 04:46 PM
  #13502
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by wcrase101 View Post
I went from 5/5/2 to 5/7/2 and it really made a differance in front tire wear.
yeahp. Even the brakes are very front biased with that 5/5/3 set up. hopefully thickening the middle will balance that out as well. The center diff just seems not as engaged as it should be (to me) with 5k in it. Even manually spinning the wheels, I want it to turn the motor sooner than it is.
lowroad is offline
Old 07-03-2011, 04:51 PM
  #13503
Jstall7543's Avatar
Originally Posted by Bondonutz View Post
Q for racing Guru's, I'm trying to decide which WT diff fluids to try first in my SCTE.
Our local tracks are generally a on the small side and tight, loose and dusty is the normal track condition. Should I go with 5/5/3 , 3/3/2, 3/3/1 or grease ?
I drove my buddys SCTE with 5/5/3 and I really liked it but could something else be a wiser choice ???
Thanks for any input
I run tight indoor clay and love the stock
grease, it seems to work great. You should try it atleast for a reference.
Jstall7543 is offline
Old 07-03-2011, 05:01 PM
  #13504
liftedcj7on44s's Avatar
This is interesting, I was running the truck pretty hard in the yard. Ran it for about 20 minutes or so and pulled to my feet to shut it off.
Took the lid off and my pinion gear fell off. I guess it fell off as soon as I stopped.
I never put loctite on it so I dropped a bit on the screw and popped it back on. Good thing it did not break the motor shaft.
At any rate I am loving this truck except 1 thing I cannot stand about it.
The stock Chassis Is too dang soft. Not sure what material it is but it is just too soft and I may just go aftermarket.
Also I added some more pre load to the rear shocks and it seems to jump better for me.
liftedcj7on44s is offline
Old 07-03-2011, 05:24 PM
  #13505
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by CHIZZLE View Post
Yep, everything is in place for sure. The more I spin it by hand though the better it's getting. It's really not that bad, just seems I can feel the teeth a little more than what I'm used to. I was running my Jammin SCRT10 on Thursday. Pretty certain that's the last time I'll drive it. Should have this thing ready to go tomorrow. Can't wait to get it on the track!
if its not binding i wouldnt worry about it. You should of been at ff sat, it was fun. tq only by .5 sec, and made one mistake in the main and lost 1st.
losi_racer is offline
Old 07-03-2011, 05:46 PM
  #13506
badassrevo's Avatar
The rear diff went bad on my truck today. I have been running the Chrispins from day one. The spider gears lost their teeth. I did the OFNA mod at the track and had it back together in time for the main. It was areally good turn out today, there were 19 4x4 SCT in attendance. I qualed 5th and finished 5th.
badassrevo is offline
Old 07-03-2011, 05:48 PM
  #13507
per4m28's Avatar
Trader Rating: 58 (100%+)
+1 Just hope we can get a hold of some more soon!!
per4m28 is offline
Old 07-03-2011, 05:51 PM
  #13508
Trader Rating: 31 (100%+)
Default SCTE Parts?
anyone have a clue as to when the SCTE diff gears are going to be avaliable?
wfoster34 is offline
Old 07-03-2011, 06:08 PM
  #13509
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
So you must be Doug. Yeah, Jeff told me about it. Seemed like you guys had some good racing going on. Wish I could've been there but I was out of town.
CHIZZLE is offline
Old 07-03-2011, 06:26 PM
  #13510
Originally Posted by Chase1472 View Post
no I run OFNA diff oil but I use the mobel 1 grease on the out drives to seal the oil in.
Put it on the rim of the outdrive case?
sluggoman is offline
Old 07-03-2011, 06:28 PM
  #13511
I bought a MM Pro, and a tekin motor. I don't have wires to connect the two. I need to solder a wire that has bullet connectors to the motor. Where do I find this wire/bullet combo. I bought wire, and bullet connectors but it's impossible to get the wire and solder into the back of the bullet connector
Old 07-03-2011, 07:12 PM
  #13512
R6cj69's Avatar
Trader Rating: 20 (100%+)
Last week Horizon told me the week of the 11th.
I'm waiting on a set too...
R6cj69 is offline
Old 07-03-2011, 07:26 PM
  #13513
Grab a small cardboard box poke a couple holes in it to sit the bulletts in.Heat the bullets with your soldering iron put a little puddle of solder inside the bullet connector.Then touch the soldering iron to the bullet to heat it up while you place your wire into it.Then lift the heat.Theres plenty on the internet about soldering
Losi57 is offline
Old 07-03-2011, 08:21 PM
  #13514
Some good racing for sure...Jeff,Doug and Josh just killing it out there..Low to mid 25's for lap times....Pretty sure that was the last time I'm gonna race my slash.
Getting into the truck tonight adding chrispin's and washers, center diff drive's. The Losi looked good right outa the box when Jeff was driving it..... killing it. I'm just woundering what kinda worms I might be opening going to Diff fluid's.
How you setting you'r diff's up?
fullpull is offline
Old 07-03-2011, 08:52 PM
  #13515
CHIZZLE's Avatar
Not sure yet. Kind of depends on what's on my shelf, haha. I put 5K in the front but that's the only one I did. I'm gonna set the whole truck up tomorrow. Probably start out with 5/5/3 since that's what I was running in my scrt10.
CHIZZLE is offline
