Like Tree9Likes
Old 06-26-2011, 07:48 PM
  #12856
So, where was it that I can find those chassis again?
SC_RAGE is offline
Old 06-26-2011, 07:49 PM
  #12857
Originally Posted by liftedcj7on44s View Post
Is anyone using Some sort of glue to keep the shock boots on? Every time I blow the truck off with air they come loose from the top of the shock and I have to fiddle with them.
I took mine off. They bind the shocks up. And they tear after a short while.
SC_RAGE is offline
Old 06-26-2011, 07:52 PM
  #12858
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
What options are there, as far as shock towers go, for running 1/8th shocks?
CHIZZLE is offline
Old 06-26-2011, 07:54 PM
  #12859
liftedcj7on44s's Avatar
But they look so cool
Remind me of the shocks on a Baja 5T
liftedcj7on44s is offline
Old 06-26-2011, 07:55 PM
  #12860
Go Carbon, You will have to make the holes bigger.
SC_RAGE is offline
Old 06-26-2011, 07:56 PM
  #12861
So do the truck nuts, but I took those off too.
SC_RAGE is offline
Old 06-26-2011, 08:06 PM
  #12862
onefast8's Avatar
Trader Rating: 41 (100%+)
Anyone have a rough idea what king of timing advance to run with a mmp on a 1410?
onefast8 is offline
Old 06-26-2011, 08:13 PM
  #12863
wcrase101's Avatar
none, for the most part you are just gonna get heat.
wcrase101 is offline
Old 06-26-2011, 08:16 PM
  #12864
CHIZZLE's Avatar
Well, I definitely want carbon. What I'm wondering is, what companies are making taller towers for this reason? Or, will just the stock height tower work fine? I don't have my truck yet so that's why I'm asking. It's coming in on Tuesday but I'm just trying to get ahead of the game.
CHIZZLE is offline
Old 06-26-2011, 08:17 PM
  #12865
Low timing, If you want speed just gear up. I ran a 18 and 16 tooth and had a max of 124 degrees.
SC_RAGE is offline
Old 06-26-2011, 08:18 PM
  #12866
I think the jammin towers are set up best for 8 shocks.
SC_RAGE is offline
Old 06-26-2011, 08:26 PM
  #12867
Cult Racing's Avatar
Trader Rating: 42 (100%+)
SNR has the taller towers, but most people just run the regular tower height.
http://www.snrgraphite.com/index.php...ex&cPath=13_14
Cult Racing is offline
Old 06-26-2011, 08:27 PM
  #12868
Jstall7543's Avatar
Those bodies look awesome, Might have to have one done up for my truck.
I have another question. Has anyone noticed that the front outdrive cup for the center Diff gets pretty hot after running the truck?
Could it be motor heat transferring from the motor to the motor plate then to the CD?
Weird, my center diff rear outdrive was 35deg hotter than the front. Probed 110 after a pack. Kinda warm.
Jstall7543 is offline
Old 06-26-2011, 08:44 PM
  #12869
I never really felt the rear out drive vs the front one i do know the whole rear CV shaft was quite warm to the touch. I am sure the rear get's just as hot if not hotter.
If the out drives are getting that hot then I could only Imagine what that does to the center diff fluid once it heats up. I would imagine that could change the handling characteristics of the truck quite a bit.
I felt my motor at the same time when I felt the out drive and the motor was not really all that hot. I was able to hold the motor for as long as I wanted so I know I was not overheated or anything.
Old 06-26-2011, 08:57 PM
  #12870
Jstall7543's Avatar
Ya, I imagine the grease gets thinner with heat. This is where regular fluid would probably be better/more consistant. But I'm more than happy with the grease. I might switch to 1000 in all 3 diffs, I like the light feel.
Also I should mention that I put on a clinic at the track today lol! spanked my best friends fully pimped bump 2.0, and my other friends sc104x4, it was so tight, like it was nothing! I did practice for 8hrs without them though in secret! It felt really good lol! They were like WTF when I broke out a losi! They thought I had the sc104x4! Surprise!
