FYI, 3rd shipment just arrived at rpphobby.com. I ordered one earlier today and it shipped via FEDEX within an hour. Awesome.
will these work to replace the washers between the diff gears and the blocks?
http://www.amainhobbies.com/product_...3x5mm-Shim-Set
jesus dude, just buy some shims already, yes!
2s on 20t is fine. 3s on 20t isn't because of heat. Its been said before....the 1415 on 2s is a straight dog! yeah if you gear it high it will go faster on 2s but why wd you wanna do that when the 1410 is a rocket on 2s. Been running the combo since the day the SCTE was released. Tested 20T, 18T, and 16t all on 3s. I'm a basher so i don't use 2s.... Only used 2s with the 20t once because my 2s batteries aren't great and were swelling. Like Salad said Use -the 2400 the way it was designed(on 3s)
Not sure what has changed in the last year that people think 2400kv on 2S is enough. Last year if someone asked to run a 2650kv MM in a 4wd SC on 2S everyone looked at them funny. That motor needs 3S to perform how it was designed. It will work on 2S but the 1410 is WAY better.
I like the 1410 for indoor, but have to say the 1415 on bigger tracks outdoors is better for me.
1410 on RX8 is good but on MMP I couldn't gear high enough for the top end I needed without pushing the MMP to it's heat limits. I run tight indoor with one 40ft straight, not enough air flow I guess. Depends on how hot it is in your area. With RX8 and ballistic 5.5 with 17t temps are 130/130 after a 2s 5600 60c TrakPower. Loving it!!! Threw the 1410 in one of the parts bin's! The 1410 ran amazing in my ultra light hyper, but not this beast!
I might try it again after I lighten the truck over the next couple weeks.
