Like Tree9Likes
Old 06-16-2011, 12:19 PM
  #11956
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by stompy View Post
I had same issues with my Ten-T!!!!!
interesting.
Also, didn't casper say he just runs no droop screws? my truck is apart for a diff rebuild and I pulled em.
lowroad is offline
Old 06-16-2011, 12:21 PM
  #11957
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Get the Titanium turnbuckles and a new set of ends (Lunsford or Losi 8ight 2.0). The stock steel ones will lose their settings every time you bump something.
Originally Posted by jasonwipf View Post
I don't crash much. I clip corners sometimes taking them tight and I "Hope" I don't endo much. the fact that this thing jumps much like a buggy and not the forward flipping traditional corr trucks is why I got it. Does front arm parts brake much or certain shock towers?
ChrisAttebery is offline
Old 06-16-2011, 12:22 PM
  #11958
8ight-e's Avatar
Trader Rating: 58 (100%+)
I race hard man.. no issues w/ a-arms or parts to date, it has been a tank iMO. I also run the rear stock plastic hubs w/o issues (knock on wood). I think in the cold some of these parts are more brittle and you see some breakage but in the warm weather, they are pretty durable.
The diff's are the only weakness.. No point in going on about his issue as it doesn't help at this point. A release of HD diff's and HD parts to buy on your own would make most happy, it's just the time frame that most are upset with at this point. Being good hobbyists many have figured out ways around this issue to keep racing for the time being
8ight-e is offline
Old 06-16-2011, 12:28 PM
  #11959
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by lowroad View Post
interesting.
I run droop screws in the rear with the 8ight droop pad mod. Fronts I run a full droop.
Casper is offline
Old 06-16-2011, 12:36 PM
  #11960
lowroad's Avatar
gah.So...again, that means, drill where I see the marks, tap for 4-40, then screw those 8ight droop screws into the chassis?
lowroad is offline
Old 06-16-2011, 12:47 PM
  #11961
Originally Posted by hacker07 View Post
We are checking in some right now, actually QA'd them on monday. And another shipment hits in about 3 weeks.
Heh, how about you take one of those trucks apart and send me the three diffs
Lon_L is offline
  #11962
Casper's Avatar
Sorry I must have misseed or misinterpreted the question, but yes do exactly as you described. I used some thread lock on the screws as well.
Casper is offline
Old 06-16-2011, 12:50 PM
  #11963
lowroad's Avatar
You didn't misnterpret, I did. They screw in from the top so that the button head is resting under the arm, right? Not familiar with the 8ight platform really.
oh wait...the 8ight screws go in from the top so that the grubs hiot THEM and not the chassis right?
lowroad is offline
Old 06-16-2011, 12:56 PM
  #11964
larlev's Avatar
I walked to the location in the warehouse myself and I can tell you, its a 50/50 shot. Not sure about PCH.
Just fill out the form on Losi.com or HH.com
HaHa...I'll pay you a little extra if you were to walk back again when my order is being pulled.
larlev is offline
Old 06-16-2011, 01:07 PM
  #11965
KingdomRacer's Avatar
+1
KingdomRacer is offline
Old 06-16-2011, 01:31 PM
  #11966
10sctrel0v3r's Avatar
what exactly is full droop? front arms level across?
10sctrel0v3r is offline
Old 06-16-2011, 01:35 PM
  #11967
Asharus's Avatar
Trader Rating: 42 (100%+)
I think it's when there's no compression on the suspension, AKA while you're in the air.
Asharus is offline
Old 06-16-2011, 01:54 PM
  #11968
Casper's Avatar
You put the screws in on top of the chassis so the droop/set screws in the arm hit the "head" of the droop pads. The droop pads are steel so they don't dent or wear like the alum chassis.
Full droop means the arms area allowed to fully extend when the tires are off the ground. The set screws in the arms are not allowed to touch the chasssis. This gives the shock the most amount of down travel.
Casper is offline
Old 06-16-2011, 01:59 PM
  #11969
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Will having that much droop on these trucks promote traction roll or will it make much difference from running say 3/4 droop to full droop?
Blitzrockey is offline
Old 06-16-2011, 02:06 PM
  #11970
lowroad's Avatar
dunsford/casper 2013
someone get on some bumper stickers STAT
lowroad is offline
