Like Tree9Likes
Old 06-09-2011, 05:24 AM
  #11491
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by 8ight-e
There is no 'match' for this and I've yet to hear a shout out from Ryan or Casper as to any availability to the grease. I agree 100% the grease has an awesome feel and is my first choice to run for the front and center. I will say a 2k diff oil is great in the rear and top pick.
Originally Posted by hacker07 View Post
I have now replied to this about 5 times. I am working on getting this packaged still but still a work in progress so there is no timeline as of yet.
Hacker thanks for the 5th reply , I didn't ignore your other posts and I didn't mean any disrespect. I was just stating you didn't have a date for availability out there yet for this item. It is nice to hear you are still working on getting it out there, as always thanks for the updates.
8ight-e is offline
Old 06-09-2011, 06:30 AM
  #11492
russp's Avatar
Originally Posted by BmainStar View Post
LOL ..Ya I am guilty..
There is a real fun small track up in Victorville,that has an over and under bridge set up and if you punch it and clear the whole thing not perfect you will hit the wall very squarely .. It takes a few laps to get it right and then no worries...but yes I have nailed it head on quite a few times..Thanx for your reply and constant help Hacker,I will try some longer screws
I know this wall very well too Riv!!!! Haha
Were almost done with the layout at Pegasus. Were gonna lay some piping this afternoon, and be ready for some racing friday night, and this saturday!!!!
Your gonna love the new layout...... Can you say monster triple, or supercross track!!! Nomajor straight away to speak of jus good flowy obstacles.
russp is offline
Old 06-09-2011, 07:47 AM
  #11493
10sctrel0v3r's Avatar
where exactly are these trucks made?
10sctrel0v3r is offline
Old 06-09-2011, 07:59 AM
  #11494
8ight-e's Avatar
downstairs.. yup I'm making them all for losi,,, well my 11yr old is helping
8ight-e is offline
Old 06-09-2011, 08:02 AM
  #11495
Buzz3's Avatar
That explains the diff pins...
Buzz3 is offline
Old 06-09-2011, 08:11 AM
  #11496
8ight-e's Avatar
Ya the little one had that assignment, but I wouldn't let her use heat ;P Afterall she is only 11
8ight-e is offline
Old 06-09-2011, 08:18 AM
  #11497
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ScottKelly911 View Post
Ryan and Casper, wish you guys were at OCRC tonight. The AE boys dominated since there was no pro Losi drivers present. AE Pro drivers Cavalieri and Jarosz went 1st and 2nd with AE support driver Matt Chapman 3rd. I didn't race tonight either, but it wouldn't have made a difference lol In that lineup, I'd have been battling for 4th or 5th most likely.
http://www.liverc.com/view_result_fi...8A_Main%29.xml
Woulda been pretty awesome to see you beat Cavalieri
Yeah I noticed that last night as well. It would have been fun to be there. Not many times you would get a shot at Cav in this class for a club race. Jarosz was giving him a run for his money though.
Originally Posted by Jedev View Post
To bad they didn't come the night before, Truhe, Evans and a whole slew of Losi guys were there. Unfortunately they were focusing on the 22.
I heard those guys were supposed to race Wed night but looks like they did not show.
Oh well
Casper is offline
Old 06-09-2011, 08:32 AM
  #11498
I am confused about the OFNA Diff set up.
On page 1 it says "OFN21003 - gears and pins (only using the small bevel gears and pins..)"
SO I would use the Sun Gears I am using now. The kit does not appear to contain the small square blocks, so I would use the ones I am now using? A couple of mine have wear, making the holes oval. Page one says to use the Kyosho washers, the stock washers are the only thing that don't seem to be wearing out, are the Kyosho better or is it that I might need more then one behind the gear.
tonyclev is offline
Old 06-09-2011, 08:40 AM
  #11499
Casper's Avatar
The kyosho shims are for in case you loose one.
Casper is offline
Old 06-09-2011, 08:52 AM
  #11500
stompy's Avatar
I just purchased a new soldering iron and was wondering what temp. to set it at?
stompy is offline
Old 06-09-2011, 09:01 AM
  #11501
Casper's Avatar
Due to the large wire we solder crank it all the way up when you are using it. If you want it to stay hot but are not going to use it for a little while turn it down about 1/2 way.
Casper is offline
Old 06-09-2011, 09:09 AM
  #11502
Trader Rating: 17 (100%+)
From what I've read through all the pages is the OFNA pins are 4mm thick so the aluminum blocks are no longer needed. The Kyosho shims are to get a good gear mesh between the OFNA planitary gears and the Losi sun gears.
mavrick0 is offline
  #11503
chucko's Avatar
does the losi SCTE need any air vent holes other then the front window ? Thanks
chucko is offline
Old 06-09-2011, 09:11 AM
  #11504
godofcable's Avatar
Trader Rating: 37 (100%+)
i put some in the rear deck of the body, helps the air escape over jumps, doesnt parachute quite as much.
godofcable is offline
Old 06-09-2011, 09:25 AM
  #11505
OK, so the Kyosho shims are bigger (Diameter) then the stock ones, so they wont just go into the groove where the block would be.
tonyclev is offline
