Like Tree9Likes
Old 06-06-2011, 06:26 AM
  #11311
russp's Avatar
Originally Posted by BmainStar View Post
Wow Fork, that was sick ness! Completely absurd Heli-Skills,great vid Thanx for sharing...Track needs sum water... LOL
Dug into the front shaft and need a complete unit no biggie,it is avail as a complete unit.What I thought was a lil Chin -see ..was that the drive pin is held in place by a plastic cover....alum would just make sense here fer sure!!!
I herd the slasher didn't work out for ya saturday, rumor is ya got spanked by a 2 wheel?? Lol
Hopefully you get the truck fixed by friday, so you can run the new layout at pegasus. I herd its gonna be pretty sick!
russp is offline
Old 06-06-2011, 06:55 AM
  #11312
pword's Avatar
Trader Rating: 30 (100%+)
Default replacement diff pin
not sure if everyone is noticing or just the set i got is bad. changed my front diff oil last night and i noticed that the losi hardened replacement pin is showing some wear after 2 races(weds). had the 'chrispins' for 4 races and showed no wear at all.
pword is offline
Old 06-06-2011, 07:21 AM
  #11313
omenwolf's Avatar
Trader Rating: 37 (100%+)
Just curious why would you take out the Chris pins and put the new losi's in, just to check them out???? I have had my chrispins in since i got mine about a month ago and i got about 25 packs through before i wanted to change the oils for a different track and there wasnt the slightest bit of wear and my blocks still look new, no ovaling.
omenwolf is offline
Old 06-06-2011, 07:54 AM
  #11314
helmsey's Avatar
Trader Rating: 18 (100%+)
I got a chance to run my SCTE this weekend for the first time against several "other" new 4x4SC trucks and had a good weekend. It could have been much better if I had checked the screw on my servo horn before the main, turns out if it backs all the way out and falls out with 42 seconds left in the main you will loose your lead fast. Still ended up getting 3rd but would have much rather had the win
I was running 5/5/3 with a MMP, Castle 1410, 16t pinion, and the truck was flying with JConcepts Subcultures. This setup was working well with a track that was rather loose.
helmsey is offline
Old 06-06-2011, 07:58 AM
  #11315
Originally Posted by 10sctrel0v3r View Post
i would of gotten those also if my lhs had them in stock, ill grab a set this weekend
same thing happened to me.
LRPO is offline
Old 06-06-2011, 08:01 AM
  #11316
Originally Posted by SaladFork View Post
I met up with the guys from Viper at DCR today for some vid and photos. Rage had the honor of kicking the Losi around all day along with the AE. Losi had zero issues all day, the AE made it half a pack and died... Front end locked up, didn't rip into it.
While the packs where charging Weylin breaks out his Heli and sweeps the track, made for a cool video.
+ YouTube Video
SWEEEEEEET!
LRPO is offline
Old 06-06-2011, 08:02 AM
  #11317
Sounds like you and Tebo had the same issue this weekend. Haha, yeah, put a dab of threadlock on that screw and let it dry, then screw it in. Should take care of this.
hacker07 is offline
Old 06-06-2011, 08:12 AM
  #11318
pword's Avatar
i had to try it. chrispin went back in.
pword is offline
Old 06-06-2011, 08:25 AM
  #11319
10sctrel0v3r's Avatar
anybody in here have any spare sun gears they would be willing to ship to me? i need at least 4 of them
10sctrel0v3r is offline
Old 06-06-2011, 08:52 AM
  #11320
Casper's Avatar
Trader Rating: 34 (100%+)
Yes the coupler is being redesigned to use a set screw to hold the pin in place.
I just tore my truck down last night and checked all that stuff out. Everything looks great. I know it is problem for some though as I have heard more then a few reports of the pin wearing through the platic coupler over time. I would consider this a wear item but is being adressed from what I have been told anyway!
Casper is offline
Old 06-06-2011, 08:56 AM
  #11321
jmc23's Avatar
Default kyosho gears
Does anyone know if i wanna do the kyosho upgrade to my diffs do i need to do all 3 diffs to maintain proper gearing or can i just do 1 at a time? rear diff gears went on me yesterday. thank god i have 2 sets of diffs. I was in second in my A main with 2 mins left and the sad thing is i raced the whole day with my kick up section of my chassis broken off. and didnt have one problem with that. I absolutely love this truck, i race against ofna's durango's and sc10's granted we all have our problems but the losi definitly has less than all of them. as the guy stated in a previous post a pro race version would be great. i have many of the upgraded parts and try to buy spares when money allows but the diffs definitly need addressing way to much slop in the outdrives. I just purchased the lightened outdrives for one set of diffs but those arent exactly cheap either, just short of a 50.00 bill. and selling the internal orings and shims in bulk packs would be great too.
jmc23 is offline
Old 06-06-2011, 09:39 AM
  #11322
ScottKelly911's Avatar
Are you talking about the Kyosho shims, or diff gears? Because I don't know of anyone running Kyosho Diff gears, several are running Ofna diff gears with Kyosho shims. If that's what you were talking about, there's a few people running them on here and may be able to help you out and all the part #'s are on the first page post. As for me, if I was going to do them, I'd do them all at once, but if I remember correctly and I could totally be wrong on this, but I think the gear ratio on the ofna gears is the same, which is probably why it works to begin with.
BTW, that's wild that the kick up broke off and you were still able to finish. That's a real testament to how awesome these trucks are!
ScottKelly911 is offline
Old 06-06-2011, 09:47 AM
  #11323
+100
LRPO is offline
Old 06-06-2011, 09:56 AM
  #11324
racerx1920's Avatar
Trader Rating: 215 (100%+)
i think this has been posted but what is the weight of the carbon tower, vs the milled aluminum ones, and the SNR carbon center top plate over the stock one
i looked on the first page before asking this to no one needs to say look at the first page there is alot of info on that
racerx1920 is offline
  #11325
gottahaveit's Avatar
Trader Rating: 31 (100%+)
Hello
Been racing the SCTE a few weeks now and I just love the truck. I have 2 TQ's and one win and my son in sportsman has 2 TQ's and 2 wins. Getting ready to do some maintence on it. Just got my Chris pins last week. My question is I love the way the truck feels with the grease in the diffs. What diff oil combo will give me the same feel?
Thanks in advance.
gottahaveit is offline
