Like Tree9Likes
Old 06-04-2011, 08:40 AM
  #11206
larlev's Avatar
Originally Posted by jmc23 View Post
So anyone know the proper way to build these diffs without them leaking? I'm not complaining just asking . I watched the Drake vid on YouTube. I'm using the black grease. Making sure the mating surfaces are flat . Used green slime and all . I fill them to the top with the sun gear on and level it off and install the top piece. Orings have been replaced. I've noticed a lot of play in the outdrives . I alternate between 2 sets of diffs change lube every 4 races. I really don't have a ton of time on the truck under 20 6min races . I do have the lightened outdrives to install on one set of diffs. Just waiting on rebuild kits to finish up. Like I say I'm not complaining. Just looking to make sure I'm not missing anything. A beefier diff set would be great. My losi 2.0 buggy never has issues. Thanks
If your breaking them apart every 4 races....are you replacing the gasket? It's not made to be kept in and reused. Gaskets don't work that way.
larlev is offline
Old 06-04-2011, 08:44 AM
  #11207
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
Is there any performance improvement with aluminum hubs? Is it worth it to upgrade bearings? What makes the expensive bearings better?
SCTRacerX is offline
Old 06-04-2011, 08:49 AM
  #11208
xxfile's Avatar
they are more expensive thats why they're better LOLOL
Go to acers or bocas website and read up on bearings
xxfile is offline
Old 06-04-2011, 09:18 AM
  #11209
[for the ones that leak, we have noticed that if you sand the diff case, it uaually takes care of it.[/QUOTE]
Exactly what/where are you sanding?
tonyclev is offline
Old 06-04-2011, 09:52 AM
  #11210
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Exactly what/where are you sanding?[/QUOTE]
Lightly sand the plastic diff case opening and make sure it is flat. Place against a glass table and make sure there are no high/low spots where diff fluid can leak from.
SEF is offline
Old 06-04-2011, 10:05 AM
  #11211
retsoorkcuf's Avatar
Lightly sand the plastic diff case opening and make sure it is flat. Place against a glass table and make sure there are no high/low spots where diff fluid can leak from.[/QUOTE]
also I use a very thin layer of black rtv (I mean thin) my leaks stopped from that side and I used a thicker o ring inside on outdrives don't know what size I have a bin of tiny o rings at work .
retsoorkcuf is offline
Old 06-04-2011, 01:00 PM
  #11212
Trader Rating: 75 (100%+)
my diffs only leak out of the outdrives. Going try to shim them I guess..
Chase1472 is offline
Old 06-04-2011, 01:15 PM
  #11213
fastpineapple's Avatar
Looks like Amain has a bunch of parts for the truck back in stock and the kits back in stock also. If your thinking about getting one go pick it up. You will not be disappointed, picked up the W last night with mine by a lap and a half. Ive almost got mine dialed!!!!!! Only other thing is trying to get the temp in my motor down ive taking all timing out of it and still high possibly thinking about going over to a tekin rx8/sc4 seems guys are able to get those to run cooler.
fastpineapple is offline
Old 06-04-2011, 01:27 PM
  #11214
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Default Speedpassion silverarrow v10
http://www.tamiya-model.com/shop/spe...-90028606.html
Looks like you can still get these from this site, they have all the turns and cheep to.
I have the 4.5 and its a wicked motor best 550 out there. Im sure saladfork can agree on that one to
Blitzrockey is offline
Old 06-04-2011, 01:58 PM
  #11215
Be very careful with the temps on those motors. They are sesnitive. But very fast. the 3.5 is insane for offroad. Demands alot of power.
SC_RAGE is offline
Old 06-04-2011, 02:00 PM
  #11216
pull your outdrives out and put some grease on the shaft of the outdrive. you can see a notch around it, that helps keep the grease in there. helps with the leaking.
SC_RAGE is offline
Old 06-04-2011, 02:04 PM
  #11217
I run the 4.5 with a 16t pinion and a little timing and turbo boost. Comes off around 165. After a 6 min main.
Old 06-04-2011, 02:10 PM
  #11218
nice, i did alot of testing on those motors. Impressive for the cost. Im currently working for viper r/c so now its my new setup. The esc is really nice. sensored only but the combo is really smooth and rips through the corners.
SC_RAGE is offline
Old 06-04-2011, 02:18 PM
  #11219
Would this be the second round of shipments with the REVISED diff pins? Thinking really hard about one of these trucks. Got a few buddies that have them and they love them. Their trucks were from the 1st shipment, so all they did was change out the diff pins and that was it. No Problems anywhere else.
Jim R is offline
Old 06-04-2011, 02:20 PM
  #11220
My rx8 always came off at 80 degrees. Cant go wrong with that.
SC_RAGE is offline
