On a bit more technical note.
I'm looking at the tenshock for the losi as there seem to be pretty good reports and it has a 5mm shaft so it doesnt need cheesy adapters.
I'm assuming the 4000 is the better chioce for the losi over the 4600.
My truck is still 100% stock except for chrispins, 7-7-3 and Calibers.
the smallest pinion i have is a 15 so i guess i should get a 11-12-13 combo for that thing.
Opinions?
Opinions?
I just got my SCTE up and running yesterday, and I took it straight to the track - and what a blast!! This thing surpries the heck out of me with the amount of torque, traction, steering... everything! Great purchase
I do have some adjusting to do so im hoping to get some pointers. I am having trouble exiting corners under moderate throttle. The backend likes to get real slippery and Im constantly fighting it to keep it straight. Im running 5-7-3 in my diffs, would putting 5 in the center help? Im also running Losi 30wt in all shocks, 2 degrees of camber in front, and 3 in the back. And yes, I am running the correct tire for my track, which is a clay high bite track.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
Opinions?
Opinions?
Alright guys... He's gone again.
ONCE AGAIN... I WILL HANDLE THE TROLLS!
You guys just ignore him.
I myself usually try to give guys the benefit of the doubt.... BUT... It seems this guy AND his "roommates 11 year old son" BOTH end all of their sentences with dashes instead of periods. Kind of a dead giveaway.
mine was doing the same thing, but i either dropped or had the spacers that do int he anchor holes the wrong way. it turned out to be the anchor rubbing the head of the screw that goes to the toe link end. i found the missing spacer and put it on the bottom side so it will give the anchor about 1/8-1/16 lift and the screw wont hit the anchor when they cross each other
anyone knows how the chamber center affects the handling ?
thanx
scte body
Hey does anyone have a stock SCTE body that they could post the overall dimensions (length and width). I bought my SCTE used without a body and was just wondering what the size was.
Jay
Jay
I'm new to the RC scene, but I do have a question since it was brought up.
How long does it take normally for a new product to have replacement parts in stock on a regular basis? While I don't agree with previous posters attitudes, the general thoughts I do agree with. If we are say 9mths in to this and still no parts...I would tend to wonder what is going on.
Just curious if this is a normal RC thing?
Are you going to race in the June series?
This isn't bad of a wait at all. Especially since lose is revving the product while they are producing it. You should have been around for the slash4x4 that was redicules!!! And they weren't even fixing problems!!!Mimed gears take awhile to get out. This seems like more of a vendor problem then an actual losi problem. Plus losi has three kits that are all using the same parts. That's alot of demand for certain wear parts.
Yes, plan on racing. I better....with all the cash I have spent on these trucks...LOL
well, it's a temporary fix unitl my 8th scale esc arrives. I'll be gentle. Sort of...
No fans, I don't do fans. Cap doubling, ok maybe. I know it's not "recommended", this is totally at my own risk, but there sure are a lot of cheesier and comparable esc's being recommended/used in this rig. thanks!
