Like Tree9Likes
Old 05-29-2011, 09:41 AM
  #10726
lowroad's Avatar
Trader Rating: 79 (100%+)
the front page says this regarding diff fluid...
Diff fluid starting points.
Indoor blue groove 5-7-3 (Front/Center/Rear)
Indoor blue groove 5-5-3 (Front/Center/Rear)
Outdoor med bite 3-3-2 (Front/Center/Rear)
I am on an outdoor med to high bite track, but does 3-3-2 sound really really low to anyone else?
lowroad is offline
Old 05-29-2011, 09:49 AM
  #10727
larlev's Avatar
lowroad....I run 5,5,3 outdoor and indoor. Maybe I'm crazy....I also run the front a few mm's higher. Seems I have it all wrong...
It works for me though...
larlev is offline
Old 05-29-2011, 09:50 AM
  #10728
racerx1920's Avatar
Trader Rating: 215 (100%+)
i run out side on an med bite/ high bite blue grove track and i ran 5-5-3 in mine. i run that everywhere i go, also run indoor clay.
im not sure what 3-3-2 is going to do. any thought?
racerx1920 is offline
Old 05-29-2011, 09:53 AM
  #10729
lowroad's Avatar
5-5-3 sounds more reaonable to me, but if anyone can tell me why 3-3-2 might offer something, I'd totally be willing to try it.
lowroad is offline
Old 05-29-2011, 10:09 AM
  #10730
Ridley's Avatar
3-3-2 will tame down your "on power" steering
Ridley is offline
Old 05-29-2011, 11:04 AM
  #10731
bigjerry's Avatar
Trader Rating: 53 (98%+)
What Bodies will interchange with the losi scte
bigjerry is offline
Old 05-29-2011, 11:21 AM
  #10732
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by SCTRacerX View Post
I would tear into the diffs, take some pics if damaged send a copy of the pics and your purchase reciept to horizon and they will take care of you i'm sure. I have never heard of anyone having those issues right out of the box.
i will do that tonight or tomorrow. for the freaking mean time i will have to marshall for todays race bought a brand new truck and i ended up marshaling lmao
the slash body i have fits like it was meant for that. the holes are in the exact same spot too. also look into the proline flow tek as well.
Mr.juarez is offline
Old 05-29-2011, 11:22 AM
  #10733
suby723's Avatar
Trader Rating: 21 (100%+)
All HPI,sc10 and the xxxsct bodies fit. I run the pre painted xxx bodies for practice, they are only 37.00. Btw the xxxsct clear (no paint) are only 28.00 and the scte bodies are 38.00. I am seeing 10 dollars more just for the scte sticker!
suby723 is offline
Old 05-29-2011, 11:35 AM
  #10734
i would like to get opinions on where and how many holes to put in the body. i bought a SCT but it sometimes makes a real good impersonation of a sail boat lol
auto2 is offline
Old 05-29-2011, 12:44 PM
  #10735
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by larlev View Post
Don't know about that...look at the team guys setups
Stock is 29.5mm front and 24.5mm rear...straight from manual.
Cut out the holes along the bottom of the windshield. The 4 holes in the rear of the body. Then cut out the two "fan" holes behind the roof in the bead of the car. These are the std minimum holes cut out in the body. Some are doing even a little more then this but I would at least do those three spots.
Casper is offline
Old 05-29-2011, 04:42 PM
  #10736
snwchris's Avatar
Well my Losi will be going on a diet soon... I thermaled twice today, once in 3rd Qual and then in a 8min Main, thermaled with 1min left.
I'm running the Novak Pro SC and Ballistic 4.5, geared at 13/40. It didnt shut all the way off, it acted more like lipo cut off... slow in forward but in reverse was fine for full throttle.
Chris
snwchris is offline
Old 05-29-2011, 04:58 PM
  #10737
Trader Rating: 75 (100%+)
Chris
Upgrade that ESC... I was running same ESC it was getting wicked hott 170-175... Then I got tekin rx8 never over 100 now no problems with anything anymore.
Chase1472 is offline
Old 05-29-2011, 05:17 PM
  #10738
Hi guys from the land downunder,
Has any body got a base setup for a low 2 med bite outdoor track,the track is hardpacked with loose stuff on top, any help would b greatly appreciated.Would like 2 make the car a bit more consistent ,the diff setup is 5,5,3 with 2 degrees camber allround and ride height of 28mm.In fast corners the truck oversteers ,then in low speed technical corners the truck understeers.
cheers,Scott
THE HUNTER is offline
Old 05-29-2011, 05:56 PM
  #10739
suby723's Avatar
cheers,Scott
One of my local tracks has that condition. For a tire setup try m2 proline bowties in the front and enduros in the back.
suby723 is offline
Old 05-29-2011, 06:05 PM
  #10740
snwchris's Avatar
Anyone running the Hobbywing ESC and have some feed back about it???
snwchris is offline
