Like Tree9Likes
Old 05-28-2011, 09:09 PM
  #10711
larlev's Avatar
Originally Posted by Integra View Post
Both Pecks set-up's on the first page are imo right. Im not too sure what Ryan's theory on why he ran the front end higher, More than likely for a particular track is all.
Ya, maybe so. It's also in the manual at 29.5(f) 24.5(r). I mainly run indoor clay smooth track, so I like mine higher in front a bit. We dont have an outdoor track here yet...it's coming.
larlev is offline
Old 05-28-2011, 09:11 PM
  #10712
Integra's Avatar
Originally Posted by hacker07 View Post
We have gone away from setups with the front that much higher than the rear. Last we ran it was blue groove outdoor and we ran 27mm front/rear.
Awesome, Thanks for clearing that up Ryan.
Integra is offline
  #10713
Trader Rating: 16 (100%+)
Default First time out
Ran at WCRC yesterday. It was my first time on the track. Got there late and didn't have practice time on their new layout. First race came in 5th (out of 10) did pretty good for a newbie. Second race came in 5th again but cut 2 seconds off my lap time. In the final started 6th ran 2nd in a 8 minute main until 2 min to go. Then the SCTE started getting loose. Started to crash and hit everything and truck in sight. Still ended up in 4th. After race I found two of my new tires unglued.
I was impressed by this truck great. I run 550 Novak 14mm rotor- MMP- gearing was 40/13 (13 the only mod 1 i had). I wanted to run 14 tooth.
I have alot of mods and weight reduction planned. I am glad I choose this car.
A929ryda is offline
Old 05-28-2011, 09:14 PM
  #10714
larlev's Avatar
Haha...it wouldn't matter for me anyway. I like it a few mm's higher in front.
larlev is offline
  #10715
crip#8's Avatar
yeah i think i will go with the chris pins. more of a permenant fix
crip#8 is offline
Old 05-28-2011, 09:25 PM
  #10716
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
got my new scte yesterday after horizon sent out a new batch of them this past week. "broke the diff in" as the manual said, changed the grease out and the shock oil and about half way into the pack at the track i got a really noisy rear diff. its more of a clicking than humming
would a really bad driveline cause that noise as well. my rear center driveline has a nasty wobble along with my front right as well.
Mr.juarez is offline
Old 05-28-2011, 09:31 PM
  #10717
Trader Rating: 75 (100%+)
wow 13? at wcrc?? gear up 16-17 that straight sweeper is HUGE!!
Chase1472 is offline
Old 05-28-2011, 09:34 PM
  #10718
larlev's Avatar
He's a good guy...put them in sooner than later to avoid any other issues.
larlev is offline
  #10719
Thanks had 17 tooth but thought it was to much gearing. I know better for next time. thanks for the advise.
A929ryda is offline
Old 05-29-2011, 01:27 AM
  #10720
BmainStar's Avatar
Hacker ,Thanks for the help with mine and Russ`s truck,we had a hella battle fri night for the podium!! Thanx again!!
BmainStar is offline
Old 05-29-2011, 03:17 AM
  #10721
Ridley's Avatar
Originally Posted by 10sctrel0v3r View Post
ugh wtf, 14mm rotor on backorder....seriously?!?!?
I have one I will sell. I prefer the standard rotor so I don't need it. PM me with an offer
Ridley is offline
Old 05-29-2011, 04:29 AM
  #10722
Originally Posted by NUC MO View Post
Problem with those pins are the taper on the end. There's not enough of the pin for the gear to ride square on that side. I've blown through two sets of aluminum square blocks using those.
I just don't get it. My chris pins are tapered on the end as well and guess what? I tore my diffs down again friday for a race yesterday and my aluminum squares, 3mm shims and the backs of my gears look perfect. Only wear I have had is the washers that go under the sun gears are wearing where they rub the metal insert on the diff case that the outdrives go through.
My cvd's are still perfect and only the rear outdrives show the smallest wear so far.
chiro972 is offline
Old 05-29-2011, 07:06 AM
  #10723
umm winning's Avatar
Mine is just like that and i believe there are many other losi's are like that...
umm winning is offline
Old 05-29-2011, 08:12 AM
  #10724
timannnn6's Avatar
Trader Rating: 140 (100%+)
Amain has 1 scte in stock as of this morning.
timannnn6 is offline
Old 05-29-2011, 09:17 AM
  #10725
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
I would tear into the diffs, take some pics if damaged send a copy of the pics and your purchase reciept to horizon and they will take care of you i'm sure. I have never heard of anyone having those issues right out of the box.
SCTRacerX is offline
