Like Tree9Likes
Old 05-28-2011, 12:00 PM
  #10666
Trader Rating: 24 (100%+)
What's a good ride height for high bite track
kerby is offline
Old 05-28-2011, 12:03 PM
  #10667
R.Bryant's Avatar
Trader Rating: 16 (100%+)
Originally Posted by wcrase101 View Post
no mods on mine, just don't over tighen it.
Yep. Same here. Screwed right on
R.Bryant is offline
Old 05-28-2011, 12:28 PM
  #10668
larlev's Avatar
Originally Posted by stompy View Post
I am new to electric. Whats the best way to set the mesh?
Don't use the paper method....it has been written about a lot. Wrong way of doing it. Just set it by eye, not too tight and not too loose. I set it so that the pinion is just out from the spur...so that it's not bottoming out in the grooves. You can spin the spur and feel when it is too tight.
I guess I put it tight and then back out just a tad. The gears today have a bulit in tolerance so that they won't completely bind. That is why the "old" paper method is wrong and shouldn't be used. I'm getting my info from numerous articles by manufs. and experienced racers.
Everyone I know that has experience does the same thing.
larlev is offline
Old 05-28-2011, 12:40 PM
  #10669
Well said" 100% correct info.
Chuck 21 is offline
Old 05-28-2011, 01:22 PM
  #10670
stompy's Avatar
[QUOTE=larlev;9178204]Don't use the paper method....it has been written about a lot. Wrong way of doing it. Just set it by eye, not too tight and not too loose. I set it so that the pinion is just out from the spur...so that it's not bottoming out in the grooves. You can spin the spur and feel when it is too tight.
Everyone I know that has experience does the same thing.[/QUOT
Thank you!! Very helpful.
stompy is offline
Old 05-28-2011, 01:40 PM
  #10671
When using MOD 1 pitch just set it by look/feel. It's pretty easy to do it that way with MOD 1 pitch as it's easy to look at the teeth.
Though with a truck that uses 48 pitch just use the paper method, it's honestly the fastest and easiest when your new. It works and still works.
twigman08 is offline
Old 05-28-2011, 02:17 PM
  #10672
shadowracer24's Avatar
Need some serious help here guys, run on a hard clay track that dusts up pretty bad during the run and I just can not seem to come up with a good tire combo to keep this thing hooked up. have tried subcultures. double dees, snipers which seem to be the better but wear out quick. Any ideas would be greatly appreciated.
shadowracer24 is offline
Old 05-28-2011, 02:35 PM
  #10673
Trader Rating: 103 (100%+)
Try Cityblocks or maybe Calibers.
jrherald420 is offline
Old 05-28-2011, 03:03 PM
  #10674
larlev's Avatar
AKA gridirons SS, or enduro SS. You want something that can get through the dust yet bend and grab the hard surface. The AKA's wear fantastic and have a good rubber compound that sticks.
larlev is offline
Old 05-28-2011, 03:04 PM
  #10675
larlev's Avatar
Stock setting works fine.
30mm front and 29mm rear..if I remember correctly
larlev is offline
Old 05-28-2011, 03:08 PM
  #10676
retsoorkcuf's Avatar
Default savox servo horn
I'm running a savox sc1256tg servo and am trying to find a aluminum horn I bought a gh racing horn and it doesnt fit so does anyone have an actual part# for any brand of aluminum servo horn just want one that fits . thanks
retsoorkcuf is offline
Old 05-28-2011, 03:27 PM
  #10677
Integra's Avatar
backwards if anything.....you wouldn't want to run your front end Higher than the rear.
Integra is offline
Old 05-28-2011, 03:55 PM
  #10678
Trader Rating: 17 (100%+)
If memory serves me they are the same spline count as a futaba servo.
mavrick0 is offline
Old 05-28-2011, 03:59 PM
  #10679
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by ScottKelly911 View Post
For those of you running the SNR CF Ackerman Bar, I remember you have to do some mod to it to work. But I can't remember what it is and what the parts are for it. Can someone post it and the part #'s to make it work. I'm getting one today, along with the CF Center Diff Top Plate and the CF Hinge Pin covers. Thanks!
where are you getting the CF hinge pin covers from?
RC*PHREAK is offline
Old 05-28-2011, 04:09 PM
  #10680
10sctrel0v3r's Avatar
I see snr has higher shock towers by 9mm....whats the advantage to using a higher tower?
i would also like to hear some feedback on this
10sctrel0v3r is offline
