Like Tree9Likes
Old 02-18-2011, 03:00 PM
  #1051
xxfile's Avatar
Welll im certainly aware of the barnyard as i lurk about on orrroad rc.ca as well and thats true stratford is only an hour and a half away and geez maybe we might see the Bieber while were there!!!..
Not to mention a trip thru the Infamous Punkey doodles corners on the way there,,,,.... lol
And yes you Socal guys there is actually a place called Punkey Doodles corners but its hard to find cuz every time they put up the sign someone steals it!!!!
xxfile is offline
Old 02-18-2011, 03:02 PM
  #1052
xxfile's Avatar
Hey YA all you guys may have Socal celebrities but WE have the BIEBER !!!lol
the young lad sure is gettin his 15 min of fame though (and prob a bit more)
xxfile is offline
Old 02-18-2011, 03:44 PM
  #1053
Trader Rating: 20 (100%+)
will there be a team setup for this truck ?
xxxtruck is offline
Old 02-18-2011, 03:53 PM
  #1054
I have been trying to get my setup posted...they are working on the setup sheet to get a few fields right and then it will be posted on the Losi website.
hacker07 is offline
Old 02-18-2011, 04:20 PM
  #1055
Trader Rating: 75 (100%+)
Cant wait to drive this thing pretty sure after reading hacker07 and others
Diffs 5 7 2 should be good I think
Novak 4.5 40/14 hopefully?
Chase1472 is offline
Old 02-18-2011, 04:53 PM
  #1056
racerx1920's Avatar
Trader Rating: 215 (100%+)
just put new out drives in my truck and rebilt everything going to try 5, 7, 2 in my diffes tomarrow see what happenes was running 5,5,2 and it was good see what 7 does
racerx1920 is offline
Old 02-18-2011, 09:44 PM
  #1057
CarlCrocco's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Casper View Post
Any std 2.2/3.0 Short coarse tire.
Anyone,
Whats a good tire for an outdoor track, with hot and dry/dusty conditions?
CarlCrocco is offline
Old 02-18-2011, 09:49 PM
  #1058
Casper's Avatar
Trader Rating: 34 (100%+)
Hot dry and dusty? I would probably try AKA enduro's or gridirons. How much dust and how hard is the base?
Casper is offline
Old 02-18-2011, 09:57 PM
  #1059
CarlCrocco's Avatar
I am up at St. Louis's Dirtburners 1/8th scale track, when we water the track it dries quickly in the Missouri summer heat.
I dont know how i would judge how hard the surface is. but theres no clay or sand in it at all.
Old 02-18-2011, 10:01 PM
  #1060
Casper's Avatar
What do the 8th scale guys run?
Casper is offline
Old 02-18-2011, 10:32 PM
  #1061
S/X Runner's Avatar
Trader Rating: 37 (100%+)
Whats the best place to drill a bleeder hole in the aluminum caps? Below or above the blatter? There is a tiny hole in the very center of the caps on the inside, how about there? I can just drill all the way through. What size hole, 1mm?
S/X Runner is offline
Old 02-18-2011, 10:41 PM
  #1062
S/X Runner's Avatar
You already have sway bars for this truck available.
http://www.losi.com/Products/Feature...rodId=LOSB2222
Since it shares plateform there are a ton of hopups already out. Adjustable front and rear pivots, alum rear hubs, alum shock caps (you can drill and put foam in for vents if you like), carbon towers, machined towers just to name a few. There will be more stuff coming as well!
What do mean by this Casper? Where does the foam go and why, what kind of foam? Also, where to drill the holes and how big?
Old 02-18-2011, 10:42 PM
  #1063
Ya Shawn I would like to think that you would want to drill in the side of the cap(much like the mugen) because that way the exces oil would bleed out when you tighting up the cap. If you where to do it in the top of the cap the excess oil wouldn't be able to bleed out. Remember this is my BEST quess.....Let me know what you find out.. Out of town for the weekend..Did the rc18t2...........
jer555 is offline
Old 02-18-2011, 10:45 PM
  #1064
S/X Runner's Avatar
Nice Jer. Get that 18t up and going so I can "test" it.
I know the 8ight shocks have it in the side also. what's up with the foam though?
Old 02-18-2011, 10:47 PM
  #1065
I ran 5/5/2 tonight in my first running of my 810e. It was a bit slow to respond to throttle for my liking but not bad. I'm trying 5/7/2 next but will probably end up with even 7/10/3 when I'm done. The small diffs don't seem as stiff for given weight of oil as a 1/8 diff.
GO-RIDE.com is offline
