ya, ive been doing some shock changes and mods to help the front stay up or actually pick up. But watching that I definitely know i wont be bending my chassis anytime soon.
Too bad the mud flaps look cool, but within 5 mins of putting my brand new body on the rear wings of the bumper cracked, it so I think I am going to have to trim the rear bumper down. I just removed my side guards, I broke one, then bought a new set as I took the old ones off I was like hmmm maybe I should just leave them off lol. I haven't raced it since to say if they made a difference for me.
I need to through my hog up on the scale.. Im sure it caries between 6.7 lbs and 7.4 lbs depending on if I'm running my 1/8th scale motor and 3s lipo. I also threw on the HB D8 Shocks so those added a little weight also, never thought I would see a Chris mod for running the big springs, but owell. They work awesome, and I never have to worry about bottoming out even with ultra low ride height. Still need to test out some diff springs and oil weights for them but I was running 30 wt all around and they seemed fine, I just picked up some 20wt and I going to see if that is going to work next. Running the greys in the rear and white up front I think, without going to look. Anyone else tried any diff springs out for 8ight shocks or D8 shocks on the SCTE?
You could spend a fortune on Ti hardware if you replaced all of it. The biggest bang for the buck is to replace the 14 large 8-32x1/2" chassis screws with AE aluminum screws, the 4 large 8-32x1/2" button head screws in the front arms with lunsford titanium, and to replace all the 5-40 locknuts(24 I believe) with aluminum ones. Couple that with Ti hingepins, and Ti turnbuckles, and thats about a 2.5~3 ounce savings in total. After that, you are down to replacing 5-40 screws of various lengths....so your return on investment will diminish drastically.
Bro the 1415 on 2s is deffinitly more sluggish than the 1410 on 2s. I think its slow also on 2s. Its been talked about before and even Salad said the 1415 with a 18 tooth pinion on 3s is the same speed as the 1410 on 2s with the same gearing. If you have the 1415 3s is when it comes alive.
It very well might have a sweet spot that is small...20t or nothing.
The price of those ti screws is ridiculous weight vs. cost
I just wouldn't use the word "sluggish" makes it sound like a turd when it's plenty fast. I do agree last week with a 18t it didnt run as nice as when the 20t is in. I use high quality batteries and have no problems keeping up with other combo's
I hear it's a beast on 3s, but thats irrelevant to my needs
and yes, I ran a 20t pinion
When I had the 1415, I thought sluggish was a pretty good verb for it
Definitely not as fast as some other choices on 2s. "Plenty Fast" was not a term I would use to describe it. Tractable, smooth, cool running, etc, might work better as a speed demon it is not. A great choice for slower drivers, drivers with heavy fingers, or drivers that like the losi in it's heavy and lethargic handling stock form as it's a motor that won't get you in trouble via explosive power output and wheelspin.
I guess I like the truck stock...until someone with a heavily lightened one beats me I'll stick with the heavy, lethargic version and sluggish motor.
Why run it lighter?
1. faster acceleration
2. faster braking
3. quicker rotation
4. longer battery life
5. lower temperatures
6. less driveline stress
7. less stress on suspension components
8. ability to run taller gearing which gives even more speed
9. better mid air correctiveness
10. Corner speed
11. Basically everything that creates speed on the track is enhanced....need I go on?
Being heavy only has one, rather dubious benefit, and thats hackability. I'm not a hacker, so I don't consider that a benefit. I don't see any negative attributes of being a pound lighter than stock while working through traffic as other trucks still seem to bounce off of me.....but I definitely see the benefits of that listed above while running. Having driven the truck in both forms, I know for a fact that the lighter version is night and day better than the heavy
To each his own I guess....only time you need speed is straights. Which it hangs with any other motor. Around track it doesn't really matter what you run.
If you are happy and doing well with it, then by all means keep it, and stay heavy. Like I said, that settup works good for slower drivers. Many of us, however, don't have that luxury if we want to compete as our driving ability is all very very close so settup and your vehicle becomes paramount
I raced my SCTE at the Ontario RC-Pro round 1 race at Average Joe's/Vineland Speedway this past weekend. Had a terrible qualifying and ended up somewhere in the B. Won the B by a rather large margin and bumped to the A. Started from the back in the A and won the A by again, a rather large margin.
It's cool that shortcourse doesn't blow anymore.
My truck is totally stock, slightly bent shocktowers, busted rear bumper, etc. - Running an RX8 and Novak 5.5t sc motor. Proline Sniper SC tires are dialed.
I think n sc heavier the better as these ate affected by the wind and with a heavier car it won't affect it as much.
