Like Tree9Likes
Old 05-21-2011, 08:01 PM
  #10111
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
We race on huge mother tracks here... 190 foot straights... Some other guys are running the 2650 setup, and works pretty nice. Might need it for our track.. the 1410 and MMp may work for a smaller track i would think though.
BSchorr is offline
Old 05-21-2011, 08:02 PM
  #10112
Would this be good for bashing?
Mustang63 is offline
Old 05-21-2011, 08:03 PM
  #10113
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Saturday race report. Still undefeated. Finishing order
Losi, Losi, Losi, Hyper, Losi, Slash
Truck ran awesome as usual but did have my first breakage today. I guess I am about 30 packs or so into this truck now running the eighth scale power on 3s. I have heard some say that their pin have broken in their center driveshafts. Not the case here. The pin in my center front shaft came out without breaking. I was airblowing my truck and saw the pin come flyin out. I picked it up and disassembled the shaft. What I found was that the collar that the pin rides in actually wore out. The hole became elongated. The collar is drilled out in two directions so I flipped the pin 90* and put it back together. I think this will happen again because the pin is a tad too short. I will probably end us measuring the dia. and cutting my own pins a tad longer. Hopefully Losi will look into this and make a running change. Gonna race again tomorrow.
alvinsmith75 is offline
  #10114
SaladFork's Avatar
The 2650 is going to be slower than the 1410 on 2S... Unless you are running the ERC mount you can't get a large enough pinion to match the speeds of the 1410. With an 18T we clocked the 1410 at 37.1mph on the GPS. That's plenty fast for a 190ft strait.
SaladFork is offline
Old 05-21-2011, 08:05 PM
  #10115
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
what pinion would you recomed to use with the tenshock 4600 on a medium outdoor track ?
Blitzrockey is offline
Old 05-21-2011, 08:16 PM
  #10116
chadmeth1's Avatar
would the OFNA 3mm Bore Mod 1 Pinion Gears work with the 1410 http://www.amainhobbies.com/product_...inion-Gear-16T also anyone use these yet http://www.amainhobbies.com/product_...ower-Gun-Metal
chadmeth1 is offline
Old 05-21-2011, 08:30 PM
  #10117
SaladFork's Avatar
Yup those work, they are recommended on the first page for peeps who don't want to use a reducer sleeve. 3mm is actually smaller than 1/8th by a hair, but the pinions do work.
Old 05-21-2011, 08:46 PM
  #10118
larlev's Avatar
Going to try the 19t pinion w/ the 1415 on 2s tomm for our race. Anyone tried it and have an opinion. I know it's not that big of a deal, just curious what temps and acceleration changing from 20t to 19t?
The 20t seems to work great on outdoor tracks, running tomm. on smaller indoor clay track.
larlev is offline
Old 05-21-2011, 08:50 PM
  #10119
larlev's Avatar
Originally Posted by SaladFork View Post
The 1410 is Castle's 3800kv 4 pole motor. The small one mounted is the 1410, the larger one next to it is the 1415 2400kv 4 pole.
1410 next to the Novak 4.5
Salad....what motor mount is that with 2 screws? Don't see that part number on first page
larlev is offline
Old 05-21-2011, 08:52 PM
  #10120
i run that combo on a fairly big (not huge) outdoor track and it works good. small indoor track will be a breeze.
Kotu100 is offline
Old 05-21-2011, 08:56 PM
  #10121
larlev's Avatar
You think I should go down to 18t then?
I remember 8ight saying something about rpms and the 1415....needed to run a certain pinion to work correctly. Maybe I misunderstood
larlev is offline
Old 05-21-2011, 09:01 PM
  #10122
its up to your personal preference and track layout. i wouldnt go buying a bunch of pinions but if you have em try it out and see what you like best.
*edit, it might have been in reference to the 30k rpm "sweet spot" in which a 3s would be better for the 1415, and 2s is good for the 1410.
Kotu100 is offline
Old 05-21-2011, 09:03 PM
  #10123
SaladFork's Avatar
It's the Elite RC mount for the Ten T/SCTe.
http://www.elitercd.com/
Old 05-21-2011, 09:04 PM
  #10124
Cult Racing's Avatar
Trader Rating: 42 (100%+)
14-16t pinion, i have a 4500kv motor and its a 4pole too, and i run a 15.
Cult Racing is offline
  #10125
larlev's Avatar
Your right....I just picked up a 18 and 19. I guess I'll run each in the quals and see how they do.
After reading everyones track setups, I see that you guys switch up pinions quite often it seems. Which makes perfect sense on track size.
larlev is offline
