Like Tree9Likes
Old 05-15-2011, 07:28 PM
  #9616
per4m28's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Doug D
SCTE race ready at 6.2 flat pounds w/ body. Mamba Max Pro, Novak 550, MurDogg 5500 65c
Getting it under 6 lbs. should not be a problem if desired.
nice job...very clean.
per4m28 is offline
Old 05-15-2011, 07:43 PM
  #9617
10sctrel0v3r's Avatar
which novak motor is that? didnt know that mmp would run with sensored? motor
10sctrel0v3r is offline
Old 05-15-2011, 07:56 PM
  #9618
Timbulb's Avatar
Originally Posted by Chase1472
ugh correct me if im wrong but shouldn't that motor be covered.. or can dust get in it?
It's a sealed motor, no vent holes.
Timbulb is offline
Old 05-15-2011, 08:20 PM
  #9619
Doug D's Avatar
Trader Rating: 62 (100%+)
Nah, its fine without the aluminum sleeve, we have found that they tend to run a little cooler without the sleeve on.
Thanks, the chassis has been milled so the battery sits 1.5mm into the chassis and is positioned back and as close to the centerline as possible. I also added the 2mm graphite spine to stiffen the chassis.
Novak 4.5 550 w/ 14mm rotor. Combined with the MMP its absolutely dialed with a ton of adjustability, I know some hate the MMP, but you really can't go wrong with this combo...
Doug D is offline
Old 05-15-2011, 08:22 PM
  #9620
To the guys out there running a Tekin 2650kv motor, are you guys running those on 2s? Thanks
Rooster88 is offline
Old 05-15-2011, 08:26 PM
  #9621
russp's Avatar
Originally Posted by BmainStar
Ok ..Havasu Chuck...go ahead and say(I told you so)...Waiting.. there it is..Yes my gears in the rear finally went, started to square off the spiders and nick up the suns,rear diff stopped in its tracks.Gotta say tho almost 3- months of hard running not bad,I know they wont last forever.Got 1.5 races out of my new Horizon pins
and lets just say I do not like the results Iam seeing on theses(new) pins.
That suks bout your diff. I know you ran the crap out of it for a while. My front toasted last night, and jus as I was about to hand casper his @ss in the main.....lol(well that was the dream I had). Was good to meet him and watch him run last night, that guy can drive!
Get ready Riv, bash fest next weekend in temecula!
Last edited by russp; 05-15-2011 at 08:55 PM. Reason: cuz i got schooled in 2 wheel stock by Casper! and i was driving on rails
russp is offline
Old 05-15-2011, 08:45 PM
  #9622
Integra's Avatar
Originally Posted by SaladFork
SC10 build in 15 minutes! Could have done it in about 13 minutes 22 seconds but Rage kept buzzing me with the Heli during the build.
+ YouTube Video
Awesome.
Integra is offline
Old 05-15-2011, 09:15 PM
  #9623
BmainStar's Avatar
Get ready Riv, bash fest next weekend in Temecula!
Ya looks like the Losi super truck is gonna be down for a bit That will give me time to do up the (22)..and the Slasher is gonna get the tune up this week and be ready for this weekends R/C party and race fest!!!Casper @ Peg? Dang would have been there if I had a truck to run LOL Hope parts come in soon!!!!
BmainStar is offline
  #9624
Buzz3's Avatar
I am having an issue with my Novak Pro ESC where when I turn it on all I have is steering. At first it was just cycle it off and back on and it would work. Now I am having to cycle it multiple times. I assume in time it will just quit all together. A friend is having the same issue. Any ideas? I will be contacting Novak this week.
Buzz3 is offline
Old 05-15-2011, 09:23 PM
  #9625
D-money's Avatar
Trader Rating: 31 (100%+)
yes i run mine on 2s with a 21t pinion and it hauls arse with lots of runtime
D-money is offline
Old 05-15-2011, 09:34 PM
  #9626
i think im gonna have to get that 14mm rotor for my 4.5 id didnt know that sleeve came off..
Old 05-15-2011, 09:35 PM
  #9627
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
I had 2 different Havoc Pro SC ESC's do exactly the same thing , eventually all it will do is run the fan and no lights will light up , I dont run them anymore When they work they are great , when they work that is
BashemSmashem is offline
Old 05-15-2011, 09:38 PM
  #9628
russp's Avatar
I'm gonna try to get there early so I can do some Snake hunting. Joey and Lance want to try somm bbq'd snake so I'm gonna try to find some good rattlers to cook up! Oh and were takoin the potato cannon out of retirement for this weekend too!
Oh put the 7.5 back in my mod 2 wheel losi
russp is offline
Old 05-15-2011, 10:35 PM
  #9629
Trader Rating: 76 (100%+)
I tryed 20/21 with 40 to 50 timming at 5000rpm.. wicked TQ but slow... I would get other motor mount gear up 24 or 25 to get past 30mph
Chase1472 is offline
Old 05-16-2011, 03:45 AM
  #9630
8ight-e's Avatar
Originally Posted by Dentman
Just stating what is well known in this thread.. The losi diffs are less than par.. The losi 2.0 8T blows diffs like on a daily basis at our track.. Not one losi of the 10 I run against diffs have held up. Not sure if this is just a losi weakness or not.
Only 8t rear diff's have issues and the 'real' problem most of the time is people not shimming them correctly. I went through several before understanding this. This is not a 'set it' and forget it item in the truggy. The buggies on the other hand pretty much are, I've never lost a diff in the 8ight or 8ight-e and never had to shim or adjust anything.
EDIT: Also note 8t diff issues are stripped ring/pinion gears, not the case on the scte for those having issues it's with the diff pins/gears on the inside.
Originally Posted by auto2
my brushless 810 is an absolute dream on the track. LARGE hard pack dusty outdoor.
my 4x4 sct is a whole another animal. i have no rear side bite at all. horrible loose. the same set up on the 810 does not work on the sct. caliber tires on both. is it the body? or the sctires side wall? longer wheel base? i dont get it.
both have rx8 esc. the 810 has a neu 1509 and the SCT have the novak 550 5.5 similar top speed. both on 3s
the large tripple jump the 810 made every time no matter how i hit it.
the SCT was hit and miss sometimes nosediving uncontrolablly.( it was windy out)
Reduce the weight of your truck... it will become a dream. Search this thread for a lot of weight saving ideas. Get down to under 6.25 with lipo/body race ready on the track and you will enjoy it much more. I have my setup for a large 1/8 track that is med bite with some dust posted a ways back as well. PS the 1410 is a much better motor and lighter than the ballistic in this truck.. iMO.
8ight-e is offline
