#9317
Need some advice here...I have been running my losi with the 1415 motor and I'm having an issue with spinning out whenever I begin to go into a turn and i let off the throttle. It even does it at low speed. The only thing I've changed for setup from stock is my diff fluids when I installed the Chris pins. The diffs are 7-3-2.
I thought it might be the drag brake which was at 20% so I dialed that out but it is still driving like I have drag brake on. Could it be I just have a bad motor that I need to send back into Castle?
This is driving me crazy because I know it's a good truck but right now it is very squirrley to drive spinning out in every corner.
One other piece of info is if I keep on the throttle through a turn while hard to do it doesn't spin out.
Hope this helps,
Alvin
#9318
Has any of you ran the Tekin RS Pro Esc and the 4.5t motor:
http://www3.towerhobbies.com/cgi-bin...VSEARCH=tt2139
What pinion would you guys start off with on most outdoor tracks?
The SCTE doesn't come with a pinion you have to buy one right?
#9320
I may know whats going on here. Does it spin out when you brake? Although it could be several other issues check this first. When I use 4 pole motors I find that I need to set the brake no more than 40%. I actually have my SCTE at 30%. Make sure the brake is dialed waaay out and try that. If that doesn't fix it then we can look else where. These motors are sooo powerful and that means their brake affect is just as powerful. I learned this when I tried a Tekin one day and my trucks went into the turns much better, it was because less brake.
Hope this helps,
Alvin
Hope this helps,
Alvin
For my diffs 7k is in the front and 2k is in the rear.
#9322
#9324
Start power Low
Timing Low
These are my settings and I don't have issues with spinouts.
#9325
#9326
make sure the rear shock tower isn't bent forward. If it bends too far, it binds on the shock caps. If it's just bent a little, you will notice the body fitting kinda funny. If you run a stock rear tower, and a stock rear bumper....you will eventually bend the rear shock tower beyond functionality.....regardless of what the factory Losi guys try to tell you.
Make sure the shock nuts on the tower aren't too tight, and binding the shock tops. The shocks should wiggle some when you twist them. If the nuts are too tight, it will distort the plastic insert and bind.
Check to make sure you dont have a hex thats stripping out in the wheels, Ive seen that cause some very erradic handling before they completely go out.
After that, I'd check to make sure the diff's are functioning freely.
There shouldn't be any spinning out with this truck...if you can't enter a corner extremely aggressively, there's likely something wrong with the truck.
All the time, guys come to me saying their truck doesn't handle like our group of friends. Almost always, the difference can be attributed to poor maintenance and suspension that is binding somewhere. IT'S ABSOLUTELY ESSENTIAL, that the suspension be free, or everything else you change is meaningless. A good rule of thumb is "SLOPPY IS FAST"
#9327
I run LVC in NiMh mode but to be safe 3.0V per cell is not a bad idea if you run for long periods of time
Forward only mode
Timing high
Brake 80%
4% dead band
2.4ghz mode
Drag brake 0-4%
Minimum brake 12%
I think that is most of the settings. Going off memory here as I don't have the software on this computer.
Forward only mode
Timing high
Brake 80%
4% dead band
2.4ghz mode
Drag brake 0-4%
Minimum brake 12%
I appreciate the info!
#9328
The very first thing I would do, is take all the shocks off, and make sure the arms pivot free on the hingepins. 99.9% of pre built vehicles...they do not move smoothly. They should flop freely when you turn the car upside down, then rightside up....should be zero friction essentially. If they don't, use a 3.5mm reamer on the arms. The captured rod ends also have a habit of biting on the balls a little too hard and can cause binding...I suggest the better losi 8ight 2.0 rod ends. they almost never bind. The set screws that snug up the swaybars may also be too tight. Back those out till there's slop in the swaybars and it wiggles around.
