Like Tree9Likes
Old 05-11-2011, 07:13 PM
  #9256
Originally Posted by SCTRacerX View Post
I run the Castle 2650, and Tekin 2650 in my SCTE and it's a great motor, fast powerful and good run times with no heat. I think I like the Tekin a bit better seems to be more controllable, Still need to get it on the track and do some time comparison with the Castle 1410 to see what is helping me turn faster times.
A guy at our track runs the Castle 2650 on 2s and in a drag race down the straight he has almost exactly the same acceleration and speed as my 1410.
Jedev is offline
Old 05-11-2011, 07:16 PM
  #9257
Thank you for sharing. an interesting topic. + rep
usbbellek5 is offline
Old 05-11-2011, 07:31 PM
  #9258
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
I run 3s shhh...
SCTRacerX is offline
Old 05-11-2011, 07:45 PM
  #9259
Alright guys finally got all the parts in today and ran my scte. I ended up going with the "Casey Peck" set up. I got both the "Crispins" and "Horizonpins" delivered the same day. Ended up installing the horizon pins. They just seemed to have a little better fit. Also took what I thought was most peoples good advise on here & started out with the 1410 motor w/18 tooth pinion & Rx8 speed controller. Also got a few gensace 40c 5000mah packs. All I can say is WOW!! This sucker hauls!! Actually seems faster then my old nitro powered 1.0 8ight buggy was. Just made a few passes up and down the street. Can't wait to get it to the track!!
arrtay is offline
Old 05-11-2011, 08:16 PM
  #9260
SCTRacerX's Avatar
I really am happy with my Gen's Ace lipos as well. Glad to hear your up and running!! It probably is faster than your 8ight lol, a few guys on here say they can run almost identical times as the 1/8th scale buggies which to me is amazing. Now if I could only keep all four wheels on the ground..
Old 05-11-2011, 08:18 PM
  #9261
8ight-e's Avatar
Trader Rating: 58 (100%+)
18t is pretty tall gearing for racing.. I'd suggest a 15t or 16t. I'm on a pretty large 1/8 track and 16t is more than enough.
8ight-e is offline
Old 05-11-2011, 08:25 PM
  #9262
If you had $70 to spend right now to buy a few things that are essential what would they be? (My truck is stock other than pins and tires)
chocolatemilk is offline
Old 05-11-2011, 08:33 PM
  #9263
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
I really like the castle 2650 on 2s and 3s. When running 2s, I actually like it more than the Novak 4.5 with 14mm tuning rotor. The 2650 has much more torque and low end grunt.
Let us know how the 2650 compares with the Castle 1410. I was thinking about trying this motor as well, but only if it's signigicantly better than the 2650.
SEF is offline
  #9264
larlev's Avatar
Shock towers...they will bend just from landings. Ask me how I know....haha
larlev is offline
  #9265
DBL15's Avatar
yeh i agree a mates running a 14 on indoors and med out side track and its heaps
i would think a 16 even on a 1/8th track would be plenty
DBL15 is offline
  #9266
KingdomRacer's Avatar
Originally Posted by Kotu100 View Post
So i'd hate to bring up the diffs again, but this isnt about the pins.
I have an issue with my outdrives having a lot of play, it seems this is a combination of the shim behind the sun gear wearing, and the metal bushing insert (seems like its drilled out a bit too much, or this could be from wear?)
Also i've replaced the front bearing on the center diff twice already and it just failed again today.
I plan on upgrading to the hardened outdrives bit want to figure out the cause of this before i put a band-aid on a gaping wound...
I take out the nut in the diff cup and top plate and CA glue them back in. It fills the void arond it and makes the fit stronger.
KingdomRacer is offline
Old 05-11-2011, 08:34 PM
  #9267
SEF
SEF's Avatar
What motor/esc combo do you have? You can get the Castle 1410 that everyone loves. I want to try this motor as well.
SEF is offline
Old 05-11-2011, 08:35 PM
  #9268
larlev's Avatar
Very interesting....what gearing you running with the 1410. I'm about to try one I think. I really like my 1415(2s), but have heard more and more good things about the 1410 as the weeks go by.
larlev is offline
Old 05-11-2011, 08:36 PM
  #9269
larlev's Avatar
I run 3s shhh...
Haha..ya on 3s the 1415 is cheating. I can barely hold on to it.
larlev is offline
Old 05-11-2011, 08:39 PM
  #9270
larlev's Avatar
I wonder if I would have been better off with a 18-19 w/ my 1415(2s) last weekend. I never hit above 145 on a 90+ day. Surely I can go down a few.
larlev is offline
