Like Tree9Likes
Old 02-10-2011, 04:23 PM
  #886
jdegraff57z's Avatar
Originally Posted by SaladFork View Post
The on/off button (not a switch) has the plugin for the Pro Gauge so you never have to unplug your receiver wire to plug in the ESC and edit it. I love this feature.
That IS a cool feature...Where is this ESC available, or is it a proto? I didn't see the R on Viper's site, nor anywhere to order that from. Checked AMain and they only have the motors.
jdegraff57z is offline
Old 02-10-2011, 04:31 PM
  #887
SaladFork's Avatar
They are not out yet, due out very soon! You can call Weylin at Viper he will give you more info when they will be officially released.
SaladFork is offline
Old 02-10-2011, 04:38 PM
  #888
DrKnow65's Avatar
Castle makes a connector cable that does relatively the same thing for all the current castle controllers.
http://www.castlecreations.com/produ...k_connect.html
Just an FYI for those that find it easier not to unplug their controller.
DrKnow65 is offline
Old 02-10-2011, 04:43 PM
  #889
I've got one arriving today or tomorrow for the SCT combo in my XXX-SCT, 'cause un-plugging is a pain in the arse I like how clean the Viper install would be with the plug-in point already built into the system. Might try one out down the road when I can afford my next R/C vehicle
Old 02-10-2011, 08:12 PM
  #890
SaladFork's Avatar
What should I do with this thing?
Old 02-10-2011, 08:43 PM
  #891
DrKnow65's Avatar
Wheelies
DrKnow65 is offline
Old 02-10-2011, 08:50 PM
  #892
SaladFork's Avatar
Damn I guess lol, better wait for the updated diff pins before I throw this in.
Old 02-10-2011, 09:17 PM
  #893
i cant get that link to work bc of my pop up software...whats the name of the connector
skyler hays is offline
Old 02-10-2011, 09:19 PM
  #894
SaladFork's Avatar
Castle Link Quick Connect
Old 02-11-2011, 04:44 AM
  #895
DBARB's Avatar
Ok I have a question. I am looking for some new batteries for this truck and I was wondering how much of a difference would be between a 2s 40c 5000mah and a 2s 60c 5600mah? I will be running a MMP and a Novak Ballistic 4.5 550.
DBARB is offline
Old 02-11-2011, 06:30 AM
  #896
DrKnow65's Avatar
Depending on the load your system see's you might get a bit more punch out of the 5600 IF the packs perform to their spec's
(I'm always suspicious of overrated stuff when you get above 40C constant).
However I don't imagine that combo is pulling more than 200amps so even the 40C 5000mah bat will put out a constant 200amps IF it's rated correctly.
I would imagine there is a significant weight difference in the 2 packs.
I am starting to always lean towards the lightest battery that will give me the run time and performance I want.
Also I find the "burst" rating a better indicator of the pack's ability to sustain voltage under hard acceleration.
DrKnow65 is offline
Old 02-11-2011, 08:08 AM
  #897
Here is what I can tell you from direct experience. They will both work. However, you will be putting almost a full load on the 40c pack and thus it will wear out much faster. I would get the 60c pack...we make a 60c 6000 and it work fantastic in this truck.
hacker07 is offline
Old 02-11-2011, 08:41 AM
  #898
dag32's Avatar
Trader Rating: 112 (100%+)
Originally Posted by hacker07 View Post
One of our guys is having good luck with the LRP SXX Version 2 esc, puts out a ton of power. Just an FYI. Looking forward to running my truck this weekend.
Ryan, what motor is he running? I have a SXX Ver. 2 laying around and I might put it to work.
dag32 is offline
Old 02-11-2011, 08:58 AM
  #899
Casper's Avatar
Trader Rating: 34 (100%+)
Tekin 550 4.5 geared 15/40
Casper is offline
Old 02-11-2011, 09:16 AM
  #900
DBARB's Avatar
Sweet thanks looks like I will be running this battery!
DBARB is offline
