Like Tree9Likes
Old 05-08-2011, 05:11 AM
  #8881
Feint Motion's Avatar
Trader Rating: 24 (96%+)
http://www.rcshortcourse.com/news/no...-torque-motor/
Feint Motion is offline
Old 05-08-2011, 05:46 AM
  #8882
RACETEK's Avatar
Trader Rating: 41 (100%+)
I've ran that setup already too. Novak with the large rotor. Still doesn't get close to the 4 pole Castle.
RACETEK is offline
Old 05-08-2011, 06:23 AM
  #8883
DrKnow65's Avatar
If the 4 pole motors are better than the new Novak stuff, do you think ROAR will ban anything over 2 poles?
Kidding, or not :-)
DrKnow65 is offline
Old 05-08-2011, 07:12 AM
  #8884
SCTRacerX's Avatar
Trader Rating: 32 (100%+)
Quote for Team Ass. Driver
finished up day one of the short course championships at 702 today, I wish I could say I did better with my truck so far, but I just cant push it without the swaybars, So I highly recommend getting some or making some when you get the truck, I might be making a bigger deal out of it than it is, but Its hard to keep up, Right now a losi holds the tq, so us AE boys have some work to do tomorrow, Wish us luck!
LOL, how's your purpose built SCT doing now??
SCTRacerX is offline
Old 05-08-2011, 07:34 AM
  #8885
Originally Posted by Cult Racing View Post
True that! just tested my bumpers out yesterday, and ran the rear without the brace and losi part of the bumper.. (practice body) i didnt have shoe goo so i didnt run my new body.
Sick pics man!
LRPO is offline
Old 05-08-2011, 07:59 AM
  #8886
Those of you concerned about weight. I use a Tbone rear bumper, but I use the one made for the Ten, not the SCTE. It is smaller, much lighter and I think looks much better. That SCTE specific bumper set is FUGLY!!!
Stock front bumper has held up very well and isn't bad looking at all.
chiro972 is offline
Old 05-08-2011, 08:24 AM
  #8887
wcrase101's Avatar
Originally Posted by nitro0619 View Post
anyone care to share the proper technique to bleed the stock losi shocks? time for a fluid change and wanna get em bled right...thx
I can't tell you the most proper way but I can at least say make sure you get all the air bubbles out by pumping the shock when putting in the oil. sometimes you have to let the shock sit for a min to let the bubbles work their way to the top. so make sure you have a way to let the shock sit up right.
and also the more oil you put in the shocks the more rebound you get out of them, so make sure you get similar rebound between l & r shock.
since you have the shocks apart then would bew a good time to inspect the seals and coat them with a sealant, I use this stuff called green slime work great! you could use grease but it will mix with the shock oil.
hope this helps.
wcrase101 is offline
Old 05-08-2011, 08:49 AM
  #8888
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
RacreTec, can you post a link on this 4pole motor please. I would like to pick one up.
kjohnsiii is offline
Old 05-08-2011, 10:23 AM
  #8889
retsoorkcuf's Avatar
there's a video on you tube by Adam drake on shock rebuild and setting rebound I used it and set my rebound and my shocks work crazy better 3/4 rebound is the way to go keeps my truck planted real good on the tight indoor clay track I run . I think the video is just called Adam drake shock rebuild sorry I don't know how to post links I'm a computer dum dum
retsoorkcuf is offline
Old 05-08-2011, 10:52 AM
  #8890
russp's Avatar
Kidding, or not :-)
Ran my mmp/ castle 3800 setup lastnight and wow this motor is a racket geared 16/40. It as fast if not faster than my hv4.5
Qualifief 2nd, due to worn out stock tires but ths motor is jus stupid. Was tripling a lon triple that mos only double!
Now to my problem I can barley run a 7 minute main with 1 warmup lap!
What kind of run time are you guys getting with this setup?
Running 5200mah 40c batt. And coming off the track at 130* in 5 minute heat race.
All in all I give this mtor a BIG thumbs up.
russp is offline
Old 05-08-2011, 11:03 AM
  #8891
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Originally Posted by LRPO View Post
Sick pics man!
Thanks, one of the guys that races at our local track takes pics while hes not racing and made some sweet shots, he took these 2 shots at a outdoor backyard track alittle bit ago too.
Cult Racing is offline
Old 05-08-2011, 11:06 AM
  #8892
8ight-e's Avatar
Trader Rating: 58 (100%+)
Diet.. reduce weight see big gains if you have not already done so. So mods are cheap, some can add up.
could be the lipo's too.. I'm taking my 2s 5400 50c speedzone packs over 10 minutes w/o issues. (racing) 1410 w/ mmp same gearing.
8ight-e is offline
Old 05-08-2011, 11:12 AM
  #8893
godofcable's Avatar
Trader Rating: 37 (100%+)
i'm right at 6.2 lbs with this combo. what do you weigh?
godofcable is offline
Old 05-08-2011, 11:23 AM
  #8894
8ight-e's Avatar
basically the same weight as mine.. what did you do to get down to 6.2 on the track? did you post up pics on the thread?
8ight-e is offline
Old 05-08-2011, 11:24 AM
  #8895
russp's Avatar
Very well could be the weight, I run the same battery in my 4.5 jammin and can get 15 minute bash sessions out of it, a 10 minute main is no problem.
Will a higher c rated battery last longer using the sam Mah as an example?
I do like the weight in my truck, make the truck feel more planted. Imo
russp is offline
