#8641
I bet they've got the right size made for some other vehicle that would work on the SCTE though. Looking on their site at other cars, there's a few that look like they might work.
http://www.lunsfordracing.com/mm5/me...gory_Code=SHMO
#8642
What JC wheels fit this truck if any?
#8643
No JC wheels fit. There are 2 wheels that fit, stock and DE makes a SCTE specific wheel.
#8646
No , the wheels have the wrong offset built into them and the only way to get them to work would be to shorten the a arms and CVDs .
#8647
http://www.amainhobbies.com/advanced...eywords=wheels
#8648
Amain has Pro-Line wheels listed under the SCTE section also.
Just because A-Main has them listed does not mean they will work, although A-Main is usually dead on about things like this.
#8649
The protracs will not fit properly and will require grinding to get full lock. they also list slash rears for the SCTE. Those also will not work.
#8651
#8652
anyone else have an issue with the front center shaft pin wearing out the holes and falling out.
ive had to replace mine twice so far and i dont even run it that much.
also, brought the timing to the lowest setting on my MMP and put the punch on low, gonna see what i get out of it for temps and run time today...
#8653
No the SCTE already has really thin hexes and zero offset wheels to keep it legal. If you have an offset wheel there is nothing you can do to make them work.
#8654
#8655
You talking about the pin at the CV joint next to the front case? We have seen this happen but it usually takes a while for it to wear through. Ryan is aware of the issue and working on it. My understanding it is considered a wear item as it usually takes a while to wear through if it does on a particular truck.
good to hear the issue is being looked at, thanks Losi CS !!
PS: I wasnt trying to suggest it might be defective, just wanted to see if anyone else was having the issues, cuz if not i could just be a problem with my setup.
maybe something causing my high temp issues...
i dunno
