Like Tree9Likes
Old 05-04-2011, 07:54 PM
  #8611
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Originally Posted by nazman01 View Post
so are number 5 pistons in the piston pack? horizon has it listed as piston pack, they all look to have 4 hole....
ya im looking for the #5 pistons too and cant find them, anyone got a link to a place who has them in stock?
Cult Racing is offline
  #8612
Originally Posted by Feint Motion View Post
Ofna pins are pretty thick, you can just toss the square block in the trash lol. So yea, you just use the pins alone.
You also need to cut the Ofna pin evenly on both sides for it to fit inside the diff case.
so how long u guys been using this ofna pin setup??? i am getting sick of trying new things and waiting.. just want one final setup that will work without issues???
bustanut666 is offline
Old 05-04-2011, 08:21 PM
  #8613
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by skyler hays View Post
since its so quiet today...let me hear your opinion about my question earlier that didnt get a response! glad its quiet on here. im in alabama and didnt have internet for 5 days due to the destructive tornadoes. had to catch up on about 50 pages i think!
My favorite setup is the 2650 on 3s. The 2200 is quite a bit heavier than the 2650. I thought with the extra weight the stock setup was a little soft and I could get better handling with stiffer springs. Stock shocks with gold springs up front would probably work well.
At the time gold springs were out of stock and I had some HB shocks, so I decided to use those. I put Associated 16mm front silver springs up front and Associated 16mm front black springs in the rear and it feels dialed.
SEF is offline
Old 05-04-2011, 08:32 PM
  #8614
larlev's Avatar
Originally Posted by KingdomRacer View Post
This is one of the best benefits with LunsfordRacing screws,
I never have to worry about stripping a screw and especially when I'm at the track and patience is out the window and I'm going too fast.
Ya that gets me too. Might have to bite the bullet and get them
larlev is offline
Old 05-04-2011, 08:39 PM
  #8615
Yes number 5 is in the pack. It has the biggest holes, not more holes.
Jedev is offline
Old 05-04-2011, 09:12 PM
  #8616
larlev's Avatar
On a real windy race day...where should body be mounted? How low is too low?
Or does it matter? No holes in body cut
larlev is offline
Old 05-04-2011, 09:34 PM
  #8617
Ridley's Avatar
Yea, I guessed as much about the weight difference in the king pins but,
It won't ever stop me from getting pretty much anything LR makes for my racers.
I like the aluminum screws idea but like the benefit of the strength of titanium over aluminum any day especially for such small screws, to each his own.
And don't you mean 8-32
............double tap
Ridley is offline
Old 05-04-2011, 09:35 PM
  #8618
Ridley's Avatar
My bad
Ridley is offline
Old 05-04-2011, 09:38 PM
  #8619
on truhe's setup sheet says number 5 pistons.... they make number 5 pistons? or are they using eight shocks? what pistons come stock?
The piston pack has 2 each of 1-5, for a total of ten pistons. The stock pistons are #3 front and rear.
hacker07 is offline
Old 05-04-2011, 09:49 PM
  #8620
sorry if this is a dumb question but I dont know anything about what certain pistons do, but when you go up on the # of the piston what does it do?
Old 05-04-2011, 09:53 PM
  #8621
Feint Motion's Avatar
Trader Rating: 24 (96%+)
but yet you want them because everyone else wants them
Feint Motion is offline
Old 05-04-2011, 09:54 PM
  #8622
haha ya because idk what they do lol
Old 05-04-2011, 09:59 PM
  #8623
Ridley's Avatar
Just drill out your stock piston with a #56 drill bit, that will get you to the number 5 piston size. #56 bits are supposed to be 1.18mm instead of 1.15mm according to the charts, but all the ones I have mic'ed have been 1.15mm.
I like the way they feel personally, give them a try.
Ridley is offline
Old 05-04-2011, 10:00 PM
  #8624
alright, but what do the different pistons do is what im asking, do they make them like stiffer or softer or what?
Old 05-04-2011, 10:05 PM
  #8625
Ridley's Avatar
Piston hole size determines your high speed compression or "pack" in RC terminology.
It will also make the shocks softer if you use the same shock fluid, but usually you stiffen the shock fluid when you go bigger on the holes.
37.5 front/32.5 +/- 2.5 is pretty good with #5 pistons IMO.
Ridley is offline
