Like Tree9Likes
Old 05-02-2011, 11:24 AM
  #8311
KingdomRacer's Avatar
The OFNA fix IMO is the better way to rebuild these diffs.
On another note, my TBR f/r bumpers came and these things are beefy just like I expected from TBR.
Front
Rear
KingdomRacer is offline
Old 05-02-2011, 11:31 AM
  #8312
Whats the weight difference between those bumpers and Losi bumpers? I wonder about some of you guys and what condition the trucks are run in 1/8 track size that your casing the jumpos or what. I mean I took this truck and hit an 8" I beam head on full speed . I definetily though I broke something . Man I was amazed on how it just kept on going. I am new 4wd driver so some of the drive techniques compared to 2wd I had to erase from my mind. Other than the gear issues I had no problem with this truck
Dynodan22
dynodan22 is offline
Old 05-02-2011, 11:48 AM
  #8313
Originally Posted by RACETEK View Post
Since you are only changing the small gears in the diff, the overall gear ratio doesn't change. The gears also have the same number of teeth as the Losi gears so the internal gear ratio of the diffs doesn't change either. Everything stays the same, except it feels smoother than before and after a few checks the teeth on the gears and the diff pins are in great condition.
Thank you, thats what I thought you had said....
Chuck 21 is offline
Old 05-02-2011, 12:03 PM
  #8314
SaladFork's Avatar
Originally Posted by Kenton View Post
Anyone running a Castle 2200 KV and MMM ESC on 3S in this truck ?? How is it ?
Yes sir! 1st truck (black front, oragne rear) is on 3S... CC 1415 with a 13T pinion.
+ YouTube Video
Originally Posted by 8ight-e View Post
here is the info off page 1 of this thread...
Chassis droop screws
Keep an eye on your chassis where your droop screws hit the stops. The small screws will chew down the chassis over time and cause premature wear. You can prevent this by installing 4-40 x 4mm Droop Screws (part#LOSA6253) http://www.horizonhobby.com/Products...rodID=LOSA6253
**** Salad you should add the 4-40 tap link just to give people a starting point.. http://www.horizonhobby.com/Products...?ProdID=DUB361
your default losa6253 link didn't work either.
Got it, and I tested the link... seemed to work. Thanks for the heads up and more info 8ight!!
SaladFork is offline
  #8315
larlev's Avatar
Have another question for you guys...
I lowered the camber link on the front shock tower. Should this affect the alignment of the truck? It tracks widely to the left now. It was perfect before. Turnbuckles are same measurement on both sides.
Also is JR servo horn size the same as the Savox?
larlev is offline
Old 05-02-2011, 12:07 PM
  #8316
BmainStar's Avatar
Originally Posted by chocolatemilk View Post
I've never ran it if I run the hard pins w stock gears if the truck is new will it work ok?
Hard to say,I ran my truck hard for two months with the stock pins and only the rear were severely worn .I made new rears and when I pulled apart them on Sat the og front and center could still be run and the rears I made looked perfect.The center and front did show ware but could have gone on for more racing.My gears and shims and alum blocks on the rear were still fine even tho the pins were shot! I have all new Losi pins in and all is fine .My friend RuusP ran his truck a few times with the og pins before going to Chris pins and tore up the side gears? So its Losi roulette on the gears for some folks but not me
BmainStar is offline
Old 05-02-2011, 12:08 PM
  #8317
I'm running 3s @ the 1/8 scale track and 2s @ the 1/10 scale track so after weighing the differences, I might keep the stock bumpers on for when I'm running 2s and throw the TBR bumpers when I'm running 3s. Time will tell.
The weights in the pics are with LunsfordRacing screws and Dynamite aluminum locknuts because I only use titanium and aluminum hardware on my racers
Old 05-02-2011, 12:12 PM
  #8318
When you change something like a camber link position, you will almost always have to change the length. Do you have a camber gauge? It really comes in handy. If your camber changed a fair bit, that could affect steering as well.
chiro972 is offline
Old 05-02-2011, 12:16 PM
  #8319
I chose not to use the optional rear brace that's included and if it becomes a problem I will fab something other than the brace that still uses part of the stock rear bumper.
Here they are mounted
Front
Rear
  #8320
RACETEK,
I was looking through your pics since you posted a link to your photobucket album and I saw that with the ofna/kyosho diff setup that you came up with the spider gears (?) don't make contact with as much of the sun gear as the stock setup. Won't that cause the sun gears to wear prematurely?
Not saying it will but it was just something I noticed in the pic. If not then if I ever notice the little washer and square spacer are grinding themselves into my gears I'll switch to your method. I just want to make sure I'm not trading one problem for another.
chiro972 is offline
Old 05-02-2011, 12:18 PM
  #8321
larlev's Avatar
Gotcha....I thought the shock tower position didnt affect the actual setting that much. It looks like the camber turnbuckle pivots at the wheel.
I have noticed there is quite a bit of slop in the wheels...both in toe and camber.
larlev is offline
Old 05-02-2011, 12:21 PM
  #8322
BmainStar's Avatar
Yup it could change alot ,if you dont have a camber gage use a soda can on a flat surface!And we are assuming you have your steering trim adjusted right.
Old 05-02-2011, 12:23 PM
  #8323
BmainStar's Avatar
Also be sure and keep an eye on your wheel nuts they loosen quite easy and will throw everything off! Upgrade to the Traxxas ones which are serrated for the Slash 4x4 ,they dont move
Old 05-02-2011, 12:26 PM
  #8324
BmainStar's Avatar
+ YouTube Video
Another great vid Fork Thanx .Love the slow mo ..If you watch it with your controller in hand you can pretend your (i`m) driving....
Old 05-02-2011, 12:29 PM
  #8325
Typical Losi slop. I say that not as a dig against Losi. Their 1/8 scale develops slop pretty early but the vehicles seem to drive just as well if not better with the slop.
Many people have reported that they buy all new plastics to take out the slop and as soon as they do their car handles like garbage until the parts settle in and get some slop.
In other words, don't worry about a bit of slop, just reset your camber and steering and don't forget to look at your toe in/out. It could also be affected.
A side note, several years ago the fastest guy in my area ran kyosho 1/8 scales. He was blistering fast and when I was looking at his buggy there was incredible amounts of slop in the wheels. Didn't seem to slow him down a bit. In real cars, all those pivot points ride on bearings so the tolerances can be very tight. In RC, if you make the tolerances too tight, nothing will move.
chiro972 is offline
