#8042
#8044
#8045
You might also want to check the ring and pinions mesh. It could be tight and getting hot enough to melt the grease down and causing it to run out.
#8048
#8049
#8051
And thanks for the heads up about Rage, we appreciate it. You know Tom Miner by chance?
#8052
Wow...very glad to hear rage is ok...get well and get to the track...it'll make you feel even better!
#8053
I kind of felt the same way myself and that's why I moved it up from 5-5-3 to 7-7-5 and I'm liking it so far. I will say this much, with the grease I felt a little drag and that could have been adding to slight temp increases.
#8054
His neighbor was throwing stuff at his dog from the other side of the fence, when Rage went outside to see wtf was up, dude pulled a gun and fired 3 shots. The guys in jail right now with 2 felony charges.
So make sure and run your packs down to LVC, cause you never know when it might be your last pack.
