Like Tree9Likes
Old 04-25-2011, 07:19 PM
  #7696
ae-Dan's Avatar
Trader Rating: 39 (100%+)
does anyone have a pic of the 1979 f-250 body mounted on the scte? i was wanting to see if the wheel base, and bumpers looked right with it.
ae-Dan is offline
Old 04-25-2011, 07:28 PM
  #7697
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Is this the one?
KIK is offline
Old 04-25-2011, 07:34 PM
  #7698
ae-Dan's Avatar
yes sir, thanks alot!!! could i get you to post one from the side
ae-Dan is offline
Old 04-25-2011, 07:39 PM
  #7699
KIK
KIK's Avatar
That's a friends truck. If you decide to get that body, I would shoe goo the heck out of it. His first time out he split the body (top of rear fender where it meets the bed, all the way up to the back of the cab).
KIK is offline
Old 04-25-2011, 07:42 PM
  #7700
ae-Dan's Avatar
when i saw it in the hobby store, thats what i said about it. it looks weak there. so i will be looking at something else.
thanks for the info, it really helped
ae-Dan is offline
Old 04-25-2011, 07:48 PM
  #7701
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Integra View Post
Randy P has made comment to using the trim as described above is NOT recommended. Granted this was for the Rs/RsPro, But i wouldn't be surprised if it was the same for the RX8. Push Control is what you want.
Well it's working your esc, potentially in a bad way when just sitting still. This trim doesn't have to be left forward all the time, just when you want... go up on the stand dail in what trim you already figured out you needed and start the race. This won't hurt any ESC, but if you have push control use it... it doesn't work the same but it is close and you can leave it on all the time. I only race, so I'm not worried about it.. I pick my car up walk it to the track turn it on toss it down walk up the steps and start racing. When the race is over I shut it off and toss it on the table. There is no idle time in my case.
So I agree if you have push control use it, expecially if you like the way it feels.
8ight-e is offline
Old 04-25-2011, 08:25 PM
  #7702
Originally Posted by Cult Racing View Post
I am! anything to help not endo.
Just wondering? Not being a smartass. Are you staying on the power @ the take off lip of the jump? Also, if the nose starts to dive did you try and hit the throttle? If you peg the gas, the gyroscopic force of the tires spinning, usually will bring the nose right up. Especially with a 4x4.
arrtay is offline
Old 04-25-2011, 08:27 PM
  #7703
Integra's Avatar
Originally Posted by Randy_Pike View Post
Do NOT use the trim to turn on brakes. First off this will prevent the system from arming properly next time you power it up. Secondly it will create a "locked rotor" issue and is not good for the esc long term.
Brake or throttle, I would assume its the same for both.
Integra is offline
Old 04-25-2011, 08:31 PM
  #7704
KingdomRacer's Avatar
All Sensor wires are universal and I didn't know there was a wire holder on the back of tekin motors. Sensor harness is held in pretty tight so I don't see a need for it
This is not good advice according to TEKIN.
We all know sensor wires are frail and just like the frailness of Neu motor wires they should be tied down as not to get damaged.
Tekin includes it in your motor/esc combos for a reason, USE IT!
KingdomRacer is offline
Old 04-25-2011, 08:45 PM
  #7705
pink_sleeve's Avatar
Trader Rating: 185 (99%+)
That can also happen if the painter scores the body to deep through the liquid mask...
pink_sleeve is offline
Old 04-25-2011, 08:48 PM
  #7706
KIK
KIK's Avatar
Are you calling Paintmonster a rookie??
KIK is offline
Old 04-25-2011, 08:56 PM
  #7707
Integra's Avatar
I personally dont like pinching my sensor wires into the little hoop, So to alleviate any sensor wire woes, I run a Super Soft CRC wire and its never flinched once. Ran it all last year in my 1/8 and all this past winter in 1/10 TC. Imo the wire tekin includes along with almost every other ESC mfg, Is too Stiff and its only a matter of time till a wire breaks causing issues (1/8 especially)
Integra is offline
Old 04-25-2011, 08:58 PM
  #7708
Hmmm.... No but I don't see how a body could fall apart any other way on its first run. Or it could have been trimmed wrong around the rear. Lexan doesn't normally just split in two no mater how thin
Old 04-25-2011, 09:03 PM
  #7709
As long as it is tied down is my main suggestion, however you do it is up to you.
But, to say the sensor wire stays in all by itself and not to see a need for a clip or tie-down of some sort is another thing all together (which was the reason for my 1st post on this).
Either way the clip that TEKIN includes works for me but I know what you mean by all these sensor wires being too stiff that causes the most problems.
Old 04-25-2011, 09:10 PM
  #7710
SaladFork's Avatar
I had a eRevo land on my SC10 and split my 09 Champ body at the cab first two laps out. Even more reason for me to hate Traxxas.
SaladFork is offline
