Like Tree9Likes
Old 04-25-2011, 03:19 PM
  #7666
Originally Posted by colter View Post
I received 2 packs of the Losb3568 last week as well. Figured it was the pins but it was not. Like you said, not complaining, but think wires got crossed somewhere. Thanks.
Same here. I appreciate the service for something I don't need, but it does seem like something got crossed up somewhere.
MotoWood is offline
Old 04-25-2011, 03:20 PM
  #7667
AnonymousUser's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Cult Racing View Post
I am! anything to help not endo.
I think it's a 4 pole motor drag thing. Now that I'm running the Novak it flies like it should.
AnonymousUser is offline
Old 04-25-2011, 03:23 PM
  #7668
KThatcher's Avatar
Trader Rating: 64 (100%+)
Originally Posted by MarqueeRc View Post
Are you running the stock rotor that was originally in the motor or the aftermarket tuning rotor that has helped ppl cool there temps in this combo??
Thanks for all the quick replys... and I am runing the stock rotor..
I will pickup the rx8, do I still need to change the rotor??
KThatcher is offline
Old 04-25-2011, 03:26 PM
  #7669
Cult Racing's Avatar
Trader Rating: 42 (100%+)
most people do, i think it would help out some.
Cult Racing is offline
Old 04-25-2011, 03:27 PM
  #7670
KThatcher's Avatar
What about the LRP SPX8 is that an option?
Old 04-25-2011, 03:31 PM
  #7671
Trader Rating: 75 (100%+)
OK need help Im running the Novak Havok SC pro and Ballistic 4.5 on a 2 cell and I cannot run for more than 5 mins and the motor gets to 180 and feels like its dumping..
I have tried 13t through 17t.
any suggestions on how to make this combo work???
try 14 pinion take that timming out of your motor or esc I got 9 mins with that set up with timming at 15
Chase1472 is offline
Old 04-25-2011, 03:41 PM
  #7672
freeman's Avatar
might be off topic here but cant find any help. I've got a 810e converted running tekin 6.5 on 3s 44spur whats would be a good starting point on pinion have 14t on now that 3.14 ratio. Any help would be appreciated.
freeman is offline
Old 04-25-2011, 03:52 PM
  #7673
FangsCPO's Avatar
What the heck does that mean??? "not endo"????????
FangsCPO is offline
Old 04-25-2011, 03:55 PM
  #7674
lmao:
http://youtu.be/1v7ggyg_Doc
keep my car straight in the air instead of the front going almost straight down sometimes
Old 04-25-2011, 04:01 PM
  #7675
FangsCPO's Avatar
lmao:
Did you ever move your battery back like I told you?? How about drag brake? Is it on and how much??
FangsCPO is offline
Old 04-25-2011, 04:05 PM
  #7676
ya i did that at franks race and no its off.
Old 04-25-2011, 04:07 PM
  #7677
SaladFork's Avatar
If you guys are nose diving due to the motor drag, add some push control, it helps big time. I have no issues jumping and I have '1' on the push in the RX8.
SaladFork is offline
Old 04-25-2011, 04:15 PM
  #7678
i have the same setup as randy pikes set up on tekins site
Old 04-25-2011, 04:32 PM
  #7679
SaladFork's Avatar
Try adding the push control, it will help. Trust me.
Old 04-25-2011, 04:33 PM
  #7680
how much do you think will help it?
