#752
#753
How about anti squat? 2? What are you guys using for the anti squat plates?
#754
Salad,
That looks like that will be my new motor for this thing. Lighter, same or more torque as a 550, longer run times, looks pretty smooth for not being sensored, I'm in. Now who has got just the motor for sale???
#755
I need help and dont have time to read back through the now 47 posts....
I just ordered the Ten-scte and want to go ahead and buy all the hop ups and goodies. Can you list for me everything i need. I know you said it works well stock but i want it all :-). This is what i know of now: aluminum rear hubs, carbon towers, and aluminum shock caps. You also said something about the protrak wheels right? Thanks in advance!
8B titanium tie rods save some weight and they have deeper threads on them so the rod ends bite better for more durability in keeping your toe and camber settings from changing like some have expereince. (I have not had a problem with the kit setup).
Alum shock tops and alum collars only add 4grams per set of shocks. They look really neat. Collars are a little easier to adjust and the shock tops will be stronger although with the SC body never really worried about the stock tops. For the 810 I would definately go this way as the shocks are much more exposed.
There will be a few more things coming as well.
Here is a page with all the part numbers.
http://www.losi.com/Products/Related...s&SubCategory=
I must say that this truck looks like a sure fire successful racer, but I'm concerned about the weight.
I like to use high voltage stuff, and I'm not sure I could add the weight and still be race worthy.
Would the weight saving hop-up parts that are available add up to save me ~120grams?
We are running the #3 pistons that come with the SCTE.
#756
Do the #3 shock pistons for the SCTE have 4 holes at 1.05mm? The answers havent been clear.
I have the stock Ten pistons and drilled 2 new holes at 1.3mm. I just recently switched to lighter fluid and it is like a whole new truck! I went from 37.5 in the rear to 27.5 and from 40 to 30 in the front. I also put in some rebound too, about 1/3 in the rear and 1/4 in the front.
#757
#759
Have you guys had any issues with the rear driveshaft going to the rear gearbox being at a angle like that wearing out the drive cups
#760
Yes, the #3 pistons have 4 holes at 1.05mm. We are running 27.5 all the way around with black up front and silver in the rear as far as springs. Ride height is at 31/29 but thinking of trying even lower. We have a little rebound in the front and id say about a 1/4 in the rear. We have been playing with actually taking out anti-squat. In the adjustable pivots, we are running the 1 adjuster or insert down.
5,3,3 sounds very weird. I might end up going 30/27.5 with black/silver just see what you are talking about.
Stock has zero anti squat?
#761
Truck comes with 3 deg of toe and 2 deg of antisquat. We are playing with 1 deg of antisquat right now Using the adjustable pivot supports.
#762
Salafork...great review! I just wanted to ask a question:
- Did you owe the guy driving the black truck money or something cuz he sure seemed to be after you?
How does the torque feel compared to the 550 sized motors?
I dropped the 4 pole Castle motor in the Ten SCT tonight. As everyone mentioned who has tested the motor... It rips hard, and the temps came off at 125º after the A-Main, which I got 2nd.
I was a doubter but no I will add it to the list of motors I would recommend. I used a 14T pinion with the 43T spur, I have not checked the pack on how many mah it pulled out. You could run a 15T no problem. I ran it with the RX8 with 10 on the timing. I tried to run a smaller body from a SCRT but it looked funky but weighed 6oz versus the body I ran tonight which is 10oz. So this pushed the truck weight to 6lbs 15oz, 10oz more than Castle recommends... Had zero effect on the motor from what I could tell.
Here is a video right after the main...
+ YouTube Video | |
#763
The 5,3,3 is weird. It seems to work pretty well though. I was skeptical. I liked 5/7/2 setup as it was stable but 5/3/3 seems to be faster. I converted my truck over the last time I was out but need to do a little more tweaking on it.
#764
Yes.
The SCTE does run slightly narrower pivots which is a running change for the Ten-T and 810 from my understanding but they all run the same toe and antisquat settings out of the box. The adjustable pivot supports are the same for all 3 cars and are the SCTE width.
#765
