Like Tree9Likes
Old 04-23-2011, 10:28 AM
  #7471
godofcable's Avatar
Trader Rating: 37 (100%+)
Are these the pins that you replace?
godofcable is offline
Old 04-23-2011, 10:30 AM
  #7472
Trader Rating: 62 (100%+)
yes
oneblackram is offline
Old 04-23-2011, 12:41 PM
  #7473
Originally Posted by Jeff Bartlett View Post
Just wanted to thank everyone who sent me tips on where to find a truck! Thanks to ABSTRACTZEN (excuse the spelling) who found one for me! Once I have delivery (shipped) confirmation he will be $30 richer Just to make sure im using this forum properly.. im not sure if it has been mentioned but someone posted how to get the grease out of the gears on the diffs. Its a common trick for 1/8 scale guys but I use a "diff dunker" (A-main) and a small mason jar full of Naptha solvent (hardware store). It works Great and fast to clean the gears.
It may be frowned upon; but regular gasoline also works.
arrtay is offline
Old 04-23-2011, 12:57 PM
  #7474
SaladFork's Avatar
Originally Posted by AnonymousUser View Post
pm me your address, I have one I'll send you.
Your a good man Anonymous!
you rule.
bet the guys in the AE thread arent this friendly
They have their days lol.
SaladFork is offline
Old 04-23-2011, 01:17 PM
  #7475
wcrase101's Avatar
Originally Posted by larlev View Post
I'm in same boat. Where was the posts regarding battery to receiver?
I'm about to see if 7v will not fry my Savox 1258. I really don't need 400 of torque in a servo...man thats strong.
couple pages back
wcrase101 is offline
Old 04-23-2011, 01:20 PM
  #7476
larlev's Avatar
Well, I guess I'm lucky. MMP, savox 1258, 1415 motor and spektrum cap.....= fixed glitch problem. No BEC needed.
I left the link v at 5.5v....did not increase to 7v like some have mentioned. I can't find anywhere that savox can handle or not handle 7v.
Been driving around with no problems now...I laugh, it's funny how fast this truck is with this motor when it's not cutting out.
larlev is offline
Old 04-23-2011, 02:12 PM
  #7477
godofcable's Avatar
I thought I read in the book that motor cleaner would work. Is that not true?
Old 04-23-2011, 02:17 PM
  #7478
shortcut's Avatar
Trader Rating: 55 (100%+)
That's what I used, seemed to work pretty good.
shortcut is offline
Old 04-23-2011, 02:56 PM
  #7479
Ridley's Avatar
Originally Posted by Integra View Post
Interesting, I watched a 9000S and 9100S Smoke within Minutes of having unregulated applied to them, 1 was on a spec radio the other a Futaba.
I only run the 9100t's, and am very careful with my endpoints. Any servo with direct power will fry in short order if the end points are off, since the servo can draw unlimited amps.
I ran them that way in 8th scale, and now with the SCTE, no issues as of yet. But, like all JR servos, the top cases suck, and the gear trains will break. I would quit using them but they keep sending me new ones
Heck, I even run the KO servo in my 2wd sct unregulated.
Ridley is offline
Old 04-23-2011, 03:02 PM
  #7480
larlev's Avatar
When you say "endpoints" how is that set? I use a DX2S radio. Is it always a good idea to limit the servo travel to just close to max.
Is "steering rate" and "travel" the same thing. I have both options
larlev is offline
Old 04-23-2011, 03:13 PM
  #7481
jhautz's Avatar
Trader Rating: 86 (100%+)
But with gas prices now days the other options might be cheaper. LOL
Thats what I used. Worked fine. Just dont use it on the o-rings. The motor cleaner can dry them out I read somewhere. Never tested it to see if it was true. Not worth the hassle to find out.
jhautz is offline
Old 04-23-2011, 03:34 PM
  #7482
8ight-e's Avatar
Trader Rating: 58 (100%+)
Limiting travel per side is setting the end points.. you just don't want to exceed what the truck is capable of turning forcing issues w/ the servo saver and your servo.
8ight-e is offline
Old 04-23-2011, 04:07 PM
  #7483
larlev's Avatar
So is it a normal thing to set it to say 90%? How do you go about finding out how far your truck turns vs. endpoint settings?
Sorry...new at this
larlev is offline
Old 04-23-2011, 04:27 PM
  #7484
shadowracer24's Avatar
The best way I have found is to turn the expo for the steering down on your radio, then turn the wheel all the way to the left and turn the expo up until the wheel wil not turn anymore without putting strain on the servo. You can usually tell that point because you will hear the servo buzz a little. Then turn the wheel to the right and repeat the process. Then you will have full throw on the steering servo without putting strain on the servo and the servo saver. Hope this answered your question.
shadowracer24 is offline
Old 04-23-2011, 04:30 PM
  #7485
SaladFork's Avatar
+1 and do the setting adjustment with the truck off the ground.
