#7456
i called around to a few LHS today looking for Mod 1 pinions. No one carries the ones with the 3mm bore. Some told me the 32P pinions were close enough, and they had them in 1/8" bore.
I've not heard this before, anyone know if 32P pinions are close to Mod 1?
Also not sure if 3mm equates to 1/8"....To the Google!!!!
#7458
I have been running JR 9100's unregulated for over a year with no issues Just watch the endpoints, and anyone wanting to do so should be fine. I run direct power to my Spektrum RX, and have no issues with rx/servo/transponder. YMMV.
#7459
Originally Posted by Email from Hitec
ORIGINAL: tohm
We have tested the HS-7955 with 7.4V lipo packs and have not had any adverse problems. Many of our team drivers/pilots have been doing this for some time now. The spec sheets will probably not change, as they were written in 2007, way before we did actual testing with the higher voltages.
At 7.4V, the torque is 387oz/in and the speed is .13sec.
Tony Ohm
Hitec/Multiplex USA
ORIGINAL: tohm
Tony Ohm
Hitec/Multiplex USA
#7461
cool I got a 9100t jr and am gonna try and bump the voltage up a little to be on the safe side. I think I noticed a little glitch on the track last time out well see today If I get a chance to practice.
#7462
Looking for all of the SCTE diet options I can find. Chris is offering a TI hinge pin set, but I haven't seen anyone put TI turnbuckles on a SCTE yet. Will a TI turnbuckle set from an 8ight work on the SCTE? Are there other options?
#7463
lunsford makes a scte set.. I snagged the front four, leaving the stock rears for better f/r balance. There is a set on amain as well. What is the weight savings on the pins? I'd consider those.
#7464
Interesting, I watched a 9000S and 9100S Smoke within Minutes of having unregulated applied to them, 1 was on a spec radio the other a Futaba.
#7465
Call it what you want, desperation or stupidity Like many im having trouble finding a new SCTE. Im willing to paypal anyone $30 who can help me to locate a new/inbox SCTE from a hobby shop in the U.S. that is willing to ship to Wi.
Email me at [email protected]
I will send the money once the deal is done! I will follow through with the tips in the order that I recieve them. Thanks!
#7466
how did it turn out?
just curious I seen that tip that was posted a little bit ago about how to run power from the battery straight to the reciever just curious about that instead of buying a bec, if I end up needing one.
#7467
Has anyone run a jconcepts truth v2 body on their scte? If so, do you have any pics? Thanks.
#7468
wow I hope 6.5 ain't too much. I was figureing half a volt would be ok. hope it don't smoke up. anyone else done this, or seen someone else do this?
I'm about to see if 7v will not fry my Savox 1258. I really don't need 400 of torque in a servo...man thats strong.
#7469
#7470
Sell that MMP and buy an RX8 and dont worry about running an external BEC or direct power . I got tired of bangin my head against the wall trying fixes for my MMP . Castle needs to address this issue once and for all IMO . Maybe if people stop using the MMP they will ?
Really not here to bash Castle as they are a great company and do make great products (I own 5 MMM systems and 2 MMP ESC's) I just think the MMP needs some beefing up .
