#7081
has anyone seen bigger lipo's coming out of china ie... cheap.
in all of the searching i've done i cant seem to find any more than 6000's
but it would be nice for some 8000 or 10000 packs as we like to run some endurance races here and there is no restriction size wise
2 cells is the only restriction
#7086
#7089
This has been one of the best threads on RCTech, everyone has been very helpful, flaming has been limited to the weekend warriors. That makes me want to help peeps who are in a parts bind.
No problem man, I have the tracking info I will PM you when I get home (it's down in my car).
#7090
Your Welcome
#7091
The 94359 servo is an older analog servo that doesn't draw as much power as the newer digital servos. I have a couple of the 94359s and they work great. Never had a problem with a MMP using that servo. However the very same MMP has needed a CAP in the Rx to prevent brown outs when using a higher end digital servo. Im not even talking about the crazy 400+oz servos that are available out there.
Bottom line is the BEC in the MMP is inadequate for anything more than a basic servo. As soon as you get into digital servos with 200+oz of torque and way more static holding power than the analog servos you can expect to start needing to add things to the system to make it all work.
If you stick with analog servos or a more basic digital servo with less torque you probably wont have a problem.
#7093
#7095
Have any used SCTE wheels or tires you wanna get rid of Salad? Discounted Bodies? If not no worries thought I'd see if you had stuff collecting dust. Just bought the last pair of beams at the LHS. So I have a pair of Newish Calibers, and 2 new pink beams anyone have an idea if I should run the beams on the front or rear?
