Like Tree9Likes
Old 04-19-2011, 11:00 AM
  #7051
Default pls help..
after returning from a great session i found loads of weeds wound up ard the rear rt driveshaft.. as it is covered with mud i stripped off all electronics and gave the truck a good scrub
later when i fixed back everything i found the rear rt wheel is not spinning as smooth as the others, and at low throttle it is obviously slower as well.
could diff gears be damaged? due to the junk being caught up at the driveshaft?
i understand there is no way of knowing til i take out the diff, but as there are no parts avail now, i jus wanna know if anyone had this problem b4? and wat was the damage like?
thanx
chiatw73 is offline
Old 04-19-2011, 11:16 AM
  #7052
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by timannnn6 View Post
I noticed that salad also runs a 40t or 43t spur sometimes. Did you have the part number for the 43 spur? Also to whoever commented about running a 11t pinion we tried that but running a 43 spur gives you more gearing options.
Actually it if anything the 43t would limit gearing options.. as you would be limited to 18 or 19t max, either spur will accept down to a 11t on a typical 4.5 motor with stock rotor. Gearing changes obviously for different kv's.. but you get the idea of the relationship and why it's pointless to waste the effort imo. But to each his own.. if you're bored I guess it's something to do :P
14t pinion on the 43t (~41)
13t pinion on the 40t (~41)
13t pinion on the 43t (~38)
12t pinion on the 40t (~38)
12t pinoin on the 43t (~35)
11t pinion on the 40t (~35)
8ight-e is offline
Old 04-19-2011, 11:20 AM
  #7053
timannnn6's Avatar
Trader Rating: 140 (100%+)
running the elite rc mount can run any pinion. but thanks
timannnn6 is offline
Old 04-19-2011, 11:22 AM
  #7054
8ight-e's Avatar
Originally Posted by larlev View Post
Does it matter?
I'm trying to keep as light as I can so yes in my case it does. If they are close I'll go w/ the de, but if the losi are a lot lighter I'll go with them.
8ight-e is offline
Old 04-19-2011, 11:25 AM
  #7055
8ight-e's Avatar
still lmiits you two on the top end of the scale :P not that they are usable unless you have a really low Kv 4pole motor. Not everyone has that nice but expensive motor mount so in your case in the usable range you gain or loose nothing other than the work to mod a spur that doesn't net you any gain. That was the only point. Hack at though.. like I said always fun to mod
8ight-e is offline
Old 04-19-2011, 11:32 AM
  #7056
jurquhart's Avatar
Trader Rating: 22 (100%+)
Originally Posted by racerx1920 View Post
just wanted to post my new proline raptor body cause its cool
It is a very cool lid I really like it
jurquhart is offline
Old 04-19-2011, 11:36 AM
  #7057
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Heading to Salem to p/u my new Ten scte 4wd truck
kjohnsiii is offline
Old 04-19-2011, 11:52 AM
  #7058
Feint Motion's Avatar
Trader Rating: 24 (96%+)
thanx
When you gave it a "scrub" did you remove you bearings? Chances are you bearings are rusted out. Check them.
Feint Motion is offline
Old 04-19-2011, 11:58 AM
  #7059
SaladFork's Avatar
Now that's dedication!! 3.5 hours 1 way.
I would do it.
SaladFork is offline
  #7060
Don't know if anyone has mentioned it but although I like the stock body, it does crack pretty easily as it is thin to save weight.
You should put some reinforcement from the lower corner of each windshield angled down to the fender towards the rear of the wheelwell. Also the rear of the body can catch on the ground and tear it up also. I cut my rear fender holes so there was more ground clearance behind the rear wheel and put some reinforcement on it.
I did the reinforcement after it was already cracked and it did that on my first heat running it. So hopefully this will help someone reinforce their nice body before it cracks up.
chiro972 is offline
Old 04-19-2011, 12:02 PM
  #7061
Originally Posted by jmc23 View Post
anyone know of any companys making an undertray for the scte pulled mine off the track after a sticky practice must have weighed 12 pounds. ill try to attach pics,
i was able to use a slash 4x4 outerwears cover. I already removed my nurf bars so it was pretty easy. its an okay fit too.
LRPO is offline
Old 04-19-2011, 12:15 PM
  #7062
Default 43 tooth spur
Losa4360
losi b is offline
Old 04-19-2011, 12:40 PM
  #7063
Nice! Ill be there to! Ill text my buddy so we can at least get 3 to have a 4wd class.
Rocky
Kenny: I just realized your picking it up not racing ...
Theroc is offline
Old 04-19-2011, 01:24 PM
  #7064
8ight-e's Avatar
shoe goo! wheel wells and that space your talking about on the front fender on every body gets hit that I run. I'm into reducing weight but only when it makes sense! I've done it on all my bodies for the last 2 years, before that I was using 100mph (gorilla tape). But the shoe goo is soo much better.
8ight-e is offline
Old 04-19-2011, 01:33 PM
  #7065
Trader Rating: 42 (100%+)
Default IN STOCK
This guy has 3 in stock
http://www.nankinhobby.com/
miket3 is offline
