#7036
Good stuff Brian. I agree I don't like limiting power via ESC. I had a ESC that I had set at 50% power and it still would thermal in 10 mins of racing. About the same time as regular power. Seems that it didn't work like it should to reduce temps, all it did for me was reduce performance. Maybe the Tekin is different mine wasn't tekin.
#7037
Does anyone know if these will work in the SCTE? And will they work in all of the bearings or just some?
http://www.rctech.net/forum/r-c-item...iff-balls.html
#7038
Ah , no those are for ball diffs like in the 1/10 buggy/Stadium trucks and some 2WD SCT's , they are not replacements for the balls in sealed bearings .
#7040
#7041
Did anyone happen to scale (or could someone scale) the stock losi wheels vs the DE Racing wheels? Which is lighter? At first I was thinking the DE, but now I'm thinking the losi wheels maybe lighter.. thanks! ** Good note to add to the first page as well :P
#7042
#7043
I installed a 43 tooth spur off the 8 2.0. I had to open up the hole in order to fit the diff. With a dremel, it took 2 minutes.
I went this route instead of current limiting on my RX8. I don't like the feel of the current limiting. I am not saying that the current limiting doesn't work, I am offering a different way to lower your temperature.
Geared 13/43 my temps after 15 minute runs are motor 160,
esc 125, TP 5300 50c battery 105.
I have my throttle EPA at 75.
I just thought I would put this info out there.
Brian
Brian
#7044
Brian
Brian
#7048
Timannn, sorry, I forgot to state that I shimmed the center diff stand off to 2mm total.
I did work with smaller pinions but I didn't get the results I was looking for. Thanks for asking though.
Part#losa3560
Part#losa3560
#7049
I noticed that salad also runs a 40t or 43t spur sometimes. Did you have the part number for the 43 spur? Also to whoever commented about running a 11t pinion we tried that but running a 43 spur gives you more gearing options.
