Like Tree9Likes
Old 02-05-2011, 06:28 AM
  #691
Guest
Originally Posted by jhautz View Post
Mamba max pro SC is the same controller as the thr MMP just different stickers. It's been out for a little while but the motor it comes with is not tue sake one it's longer and lower kv. Only 2400kv. I haven't tried one but I'm guessing it's probably not the greatest 2s motor. Probably a better motor for 3s.
But its a 4 pole motor, it should be good??
LOSIRACER77 is offline
Old 02-05-2011, 09:39 AM
  #692
KingdomRacer's Avatar
The 2400kv will need 3s in order to be ideal.
According to the rpm's of the 2400kv at 3s it should be a little smoother than the 3800kv at 2s, which could be a benefit (keep in mind that the 3800kv is found by many to be smooth too).
The only thing to keep in mind is what is allowed at your track (2s or anything goes).
KingdomRacer is offline
Old 02-05-2011, 12:35 PM
  #693
Trader Rating: 33 (100%+)
Questions??
Can anyone give me the dimensions of the batt box????
I'm wondering if a pack that is 152 x 49 mm will fit in it without making any mods....
silversam is offline
Old 02-05-2011, 03:55 PM
  #694
Blitzrockey's Avatar
Will the aftermarket say de racing rear mud gaurds and front and rear skid plates made for the ten-t fit on this ?
Blitzrockey is offline
Old 02-05-2011, 04:06 PM
  #695
Trader Rating: 31 (100%+)
Default Casper and Salad Fork
I need help and dont have time to read back through the now 47 posts....
I just ordered the Ten-scte and want to go ahead and buy all the hop ups and goodies. Can you list for me everything i need. I know you said it works well stock but i want it all :-). This is what i know of now: aluminum rear hubs, carbon towers, and aluminum shock caps. You also said something about the protrak wheels right? Thanks in advance!
flysullivan is offline
Old 02-05-2011, 04:34 PM
  #696
S/X Runner's Avatar
Trader Rating: 37 (100%+)
You could have found this in the time it took you to post
S/X Runner is offline
Old 02-05-2011, 04:52 PM
  #697
DrKnow65's Avatar
Four pole motors produce far more torque than a comparable sized 2 pole, much more efficient. We only needed 2 pole motors until the switching speed of the ESC's could deal with a 4 pole spinning 100,000rpm.
DrKnow65 is offline
Old 02-05-2011, 05:25 PM
  #698
SaladFork's Avatar
Give the other trucks something to aim for...
SaladFork is offline
Old 02-05-2011, 05:30 PM
  #699
Guest
Now we have a target to aim at!!hahaha
Old 02-05-2011, 05:41 PM
  #700
racerx1920's Avatar
Trader Rating: 215 (100%+)
the rear hubs are not really needed and they way i see it is you run them then the pin hole gets a little worn out and you get play you have to spend the 50 bucks on new ones or you can use the plastic and spend 5 bucks to replace them.
the other stuff is good, i plan on buing the aluminum towers, shock caps, shock stand offs, shock pre load nuts
protrack wheels rub a little from what, hacker07 or casper said i few posts back but will work in a pinch, i would just wate for the truck and buy the wheels that are made for the truck. protrack are not true 0 offset like the losi wheel from what i have read
racerx1920 is offline
Old 02-05-2011, 06:01 PM
  #701
jdegraff57z's Avatar
@ Saladfork
Dude, that's awesome
jdegraff57z is offline
Old 02-05-2011, 06:13 PM
  #702
Default To: SX Runner
I dont want to offend anyone
Old 02-05-2011, 06:45 PM
  #703
DrKnow65's Avatar
You could have been a little less of an ass when responding to my question, but after going back to read through the forum I see that you must not be able to help it ie. Calling everyone bags of douches. I hope for your sake you identity is not revealed and we dont ever run into each other. In short you are a coward and a pussy because you hide behind an alias and talk [email protected]! to people.
You may consider putting this kind of thing into a PM flysullivan, and I think you DO have to read through the 47 pages of this thread. Reason being is that there are multiple opinions and points of view to be considered and if only one person responded to you post, would you have taken their word as gold?
If you're going to drop $500+ on this truck when it's all said and done, you might consider ALL opinions, and that takes some reading.
DrKnow65 is offline
Old 02-05-2011, 07:01 PM
  #704
DrKnow65's Avatar
I must say that this truck looks like a sure fire successful racer, but I'm concerned about the weight.
I like to use high voltage stuff, and I'm not sure I could add the weight and still be race worthy.
Would the weight saving hop-up parts that are available add up to save me ~120grams?
DrKnow65 is offline
Old 02-05-2011, 07:10 PM
  #705
S/X Runner's Avatar
, I thought it was freaking hilarious. Chill the F out bro. Click the link and take a gander around. You will find all the answers to your questions there. I actually did you a favor and gave you an answer...
Once you are done with that....
+ YouTube Video
