#6362
I completely understand people's desire to drive on the original pins. I've had my truck for two weeks now and I'm going craZy while waiting for my replacement pins to arrive.
#6363
#6368
#6369
This problem only happened because I was running 4s and hasn't happened again on 2s or 3s
The CC 1800kv on 4s is/was a monster in this truck (torque wise) and with 5k in the CD it didn't stand a chance for the abuse I gave it
#6370
#6372
Photobucket is down for a short maintenance so here is a link to the part that I'm talking about.
In the pic on the top right you can enlarge it simply by clicking on it and you will see 2 nuts on the bottom left of the pic and those are what goes into the diff cup as well as the diff top plate.
They are metal inserts that the output spins in, well when I ran my CC 1800kv on 4s the heat that generated in the diff due to the lite oil was enough to melt the nut like notch that holds the nut in place inside the diff cup and the nut was able to spin which opened up the exit hole on the diff cup and this is where my leak was.
It wasn't until I bought a replacement diff cup that I even knew that the diff had such an insert for the output.
Anyone running 4s or higher I would definitely recommend a heavier diff fluid to avoid melting the groove for the output insert.
I don't plan on running 4s but just wanted to see what my 1800 could do in the truck and it was fun.
Hope this helps, good luck!
Here's that link:
http://www.amainhobbies.com/product_...Hardware-Ten-T
Here's that link:
thanks
#6374
Can someone tell me if I can run the diffs without the little square washer that goes between the gear on the diffpin and the diff case? Like on my 8ight 2.0?
#6375
