#6196
So for club racing at OCRC, they allow 3s setups? Because if they do, than that's great! I think the battery limit rule for 1/8 scale or 4x4 SC is misguided unless you are trying to establish a stock class.
For 4x4 SC, I've had more problems with overheating motors, malfunctioning esc's, and puffed lipos trying to push the limits of 2s (which every racer does), as opposed to being in the normal operating range of 3s.
You get more runtime, lower operating temps, and higher safety for the racer with a properly set up system.
I hope ROAR and other tracks would allow the correct battery and motor for the application.
Why not be like 1/8 nitro buggies which allows any motor up to 0.21 in size with any fuel. It's like saying you must run an RTR motor with 10% nitro for all 1/8 scale nitro buggies.
Just my rant for the day.
#6197
Put your "current limiter" at 90% on your ESC via your computer with the link. It will help alot. Also, once you get rid of the grease in the diffs, it will also remove alot of the drag the grease causes. Just my .02.
#6198
they don't have to strap their azz into it and drive it with their life on the
line like full size racers do...
I race against 2650's on 4S in RC8's & 10th SC's with 2650's on 3 & 4S with
my SCTE on 2S 4.5T 550 geared properly and win.There is a point of no
returns if people would only pay attention.
#6199
Nothing wrong with 2s for some cars, and nothing wrong with 3s for other cars. Just make a stock and modified class and be done with it. No one ever tried to save a buck running 1/8 scale and 4x4 SC classes.
#6200
I agree 100%.... R/C racers don't know when enough is enough HP's because
#6201
#6202
#6203
They should keep the 550 rules but anyone running a 6.5 or higher should be allowed to run 3S. No 1/8th scale motors in 1/10th, while they do work I feel you can get everything you need out of the 550's. Then it's just twisting ROARS arm to allow 3S and not just 1/8th motors. But we all know ROAR it won't happen.
I found this truck on 2S to be very hard on my battery packs, both HK and my race packs. Motor heat has been fine but my packs will not last as long as if I was running something lighter. ROAR wants to keep the cost down, but in the long run it will end up costing me more. This is the deep wallets class, if you can't afford to keep up with the class IMO go back to 2wd (or get a better job and quit bishin).
#6204
Did you mean to say, the Law of Diminishing Returns??
3s on a 2650 maybe with 80 EPA...4s?? the flag is going up..unless 60EPA.
You are correct though...4.5 550 in the right hands will take down and other motor combo in the wrong hands...but if you were to race the 2650 against yourself with the 4.5...I could almost guarantee the results would be different!!
#6205
You're right, there's always going to be that element that just wants more and more power and eventually meet the point of diminishing returns and have a truck that's uncontrollable and undriveable. We'll leave that to the bashers who want to run 4s for high speed runs. But for most of us, we just want to run a system that has enough power in reserve to make it over any jump on the track and have the added safety of never having to worry about heat issues or burning up motors/esc's which in the long term will save us money as well as saving the manufacturers money from having to give out replacements all the time. Honestly, I'm pretty sure all the 4x4sc's currently on the market can handle the 1/8 scale motors. I had one in my Slash 4x4, people routinely ran them in their Ofna's as well. Though they're called 1/10 scale, its much closer in build quality as well as size to an 1/8 scale class. I can put my SC body over my 1/8 scale buggy and it fits almost perfectly. True 1/10 scale would be closer to the size of the HPI Trophy Truck. Also, when I first put my truck on the track with 2s and my 1/8 system in it, my truck was so slow that it was I was at risk of getting plowed from behind on the straight. When I put my 3s in it, it was about equal to the 550 can motors. Because of the higher KV that the 550's are putting out, they have a higher top end, the 1/8th systems replace their lack of KV with higher volts. In this application, they end up pretty much equal with the exception of having a weight penalty for the 1/8. 4s or higher on the other hand would be different. If you want to drive my truck to see how it is, I think you'd see what I mean that I don't have an advantage having more power because it's actually about the same. But I do have the advantage of not having to worry about heat and burning up my motor Lastly, I want to address cost, these trucks are coming as rollers which are great because it allows people to put the motor/esc's of their choice into their rides. People are already running RX8's with the SC4X 550 motors which is on par with the price of the RX8/T8 motor/esc combos. For racers, the price difference is negligible. I really just think the rules were put in place before the class had matured and we saw what these trucks were capable of. ROAR and other race organizers should be open to changing rules as a class matures and more knowledge becomes available such as this case.
#6206
For club racing, yep, they allow it, so cruise on down. For the Big races such as the JConcepts race this coming weekend they don't because the title sponsor adheres more closely to ROAR and is in compliance to their rules.
Ryan,
Ryan,
#6208
I have no throttle control due to a badly injured throttle hand I only have
full throttle or no throttle and sometimes I miss the throttle all together
several times a lap. I do the best I can with what I got & have fun..
Heres my set ups:
702 Vegas 12/40 RX8 90% Novak 4.5 (box stock)
Havasu AZ 13/40 RX8 90% Novak 4.5 (box stock)
Coyote R/C Victorville CA. 12/40 RX8 90% Novak 4.5 (box stock)
West Coast 12 or 13/40 RX8 90% Novak 4.5 (box stock)
Temps at 10 minutes between 130 & 170 depending on outside temps.
I tried 14/40 at Havasu AZ out door track & in 7 minutes I was 210 with
an outside temp of 90+ degrees
#6209
The weight of the Losi is really pushing the capability of the equipment. These cars should really be on 3s to be safe imho.
1/10 SC is really getting similar in size and weight to 1/8 scale and it is totally retarded to run these cars on 2s. 2s batteries are really not capable of putting out the juice required. I was putting a hurting on my packs this weekend and you can feel them sagging (Thunderpower 65c...) My Hobbyking packs could barely take it.
Does 2s work? Yes. However, I like my stuff to be done right, not just good enough. Fans and the like are for improperly setup cars imho.
Going to 3s with lower kv motors is no more expensive than 2s setups.
The class is growing like gangbusters around here. We are getting a lot of nitro guys buying the cars as 2nd or third class to run outdoors. I am predicting we are going to start seeing some serious issue this summer trying to run these cars on big 1/8 size tracks in summer heat.
#6210
Losi for the win
