Like Tree9Likes
Old 02-02-2011, 11:31 AM
  #586
stinky4skin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by LOSIRACER77 View Post
Losi-chevy.
Associated-ford
Thats the way i see it!
stinky4skin is offline
Old 02-02-2011, 11:40 AM
  #587
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I see it like this:
LOSI = Dodge Viper - Heavier, stronger, simpler design, possibly a better basher.
AE = Porsche 911 4 - Lighter, more nimble, more sophisticated, possibly more maintenence
Losi-chevy.
Associated-ford
ChrisAttebery is offline
Old 02-02-2011, 11:43 AM
  #588
The SCTE is designed to be a ROAR legal truck so the motor mount is setup to run 550 motors. It is not setup to run the larger 670 sized motors.
Put the 8ight titanium tie-rods on my SCTE just to make sure they fit for you all and they fit great. The threads have more bite as well so they will hold even better. They also save 15.8 grams.
hacker07 is offline
Old 02-02-2011, 11:48 AM
  #589
fordmike65's Avatar
Trader Rating: 28 (97%+)
Losi-FORD.
Associated-chevy
That's Fordmike65's take on it
fordmike65 is offline
Old 02-02-2011, 12:26 PM
  #590
I assume they are the 4mm 8ight 2.0 Ti rods?
GO-RIDE.com is offline
Old 02-02-2011, 12:41 PM
  #591
Originally Posted by dirtracer1 View Post
Thanks for the input skyler. I'm pretty sure that the Novak will get the job done, and I'm still leaning heavely towards buying the Novak, but my concern for the Novak was if it will be running warmer temps as opposed to an 1/8th esc.....and if so.....how much warmer.
I live in Florida and will be again racing on an outside track so temps are a bit of a concern for me. It comes with a fan....right? Is it enough to keep it cool enough to not be a worry?
im sure the 8th scale would run cooler. i live in north alabama. i got my jammin in oct so didnt race on any 100 degree days. it does come with a fan.
i also run a mamba monster in my 8ight.
what i like about the novak.
thermal protection
rebuildable
programming via a push button
on board temp sensor via same push button
as i mentioned i tqued with this system(twice now) at my local track and only been racing since july. i would someday like to switch to an 8th scale system for the 4wd sc, but funds are tight and right now its getting the job done!!
skyler hays is offline
Old 02-02-2011, 12:43 PM
  #592
Casper's Avatar
Trader Rating: 34 (100%+)
He put this kit on.
http://www.losi.com/Products/Feature...rodId=LOSA6530
Casper is offline
Old 02-02-2011, 07:23 PM
  #593
hooksjk's Avatar
http://www.amainhobbies.com/product_...Package-2400kV
Do you think this will be a good motor and esc for this truck?
hooksjk is offline
Old 02-02-2011, 07:29 PM
  #594
SaladFork's Avatar
Yes if you run 3S.
SaladFork is offline
Old 02-02-2011, 07:31 PM
  #595
hooksjk's Avatar
Originally Posted by SaladFork View Post
Yes if you run 3S.
Would a 2s be to slow this motor and esc?
hooksjk is offline
Old 02-02-2011, 07:33 PM
  #596
S/X Runner's Avatar
Trader Rating: 37 (100%+)
Yes. 3 cell will get to 26640rpm. 4 cell will get you 35520rpm. 4 cell would be awesome!!
S/X Runner is offline
Old 02-02-2011, 07:36 PM
  #597
hooksjk's Avatar
http://www.amainhobbies.com/product_...Package-3800kV
Or would this motor esc be better?
hooksjk is offline
Old 02-02-2011, 07:38 PM
  #598
SaladFork's Avatar
You want something along these lines - http://www.amainhobbies.com/product_...-550-Motor-55T
4.5 or 5.5 for 2S.
Old 02-02-2011, 07:43 PM
  #599
Trader Rating: 21 (100%+)
I agree Salad. 550 4.5 or 5.5 for 2s. Just got a Fantom Fusion 2 4.5 for my truck to compare with the 5.5. Also need to take the diffs apart and see how they are holding up. Rear outdrives show signs of wear, but the rest look pretty good.
Brian L is offline
Old 02-02-2011, 08:22 PM
  #600
SaladFork's Avatar
The Fantom Fusions a KILLER motor (just am not a fan of the 3mm shaft) but Jeff is tops on customer service and quality. I am doing the same on Saturday, going to pull the diffs apart and peep the pins. I ordered more, they should be here by then.
