Like Tree9Likes
Old 03-29-2011, 12:31 PM
  #5146
Originally Posted by hacker07
We got diff pins in, I tested them and was not happy with them. Unfortunately this means another week or maybe two. I know thats not what anyone wants to hear but its the truth. We have a couple quotes finally from some companies here to make them and will be having some for you all within a couple weeks.
This has been addressed many times and we had parts air freighted in. They are at UPS in CA right now and we should get them today or tomorrow.
This sounds good to me as I own (2) SCTE's I'm running AE SC10 gear diff
pins so I'm in no hurry for the pins.
Are you going to have diff out drive cups that are harder to replace these
soft ones we have in the first run trucks??
and are you going to have Gold & Silver springs in this parts order??
Chuck
PS: I love this truck,even with it's few short comings...
Chuck 21 is offline
Old 03-29-2011, 12:33 PM
  #5147
Ridley's Avatar
I think of The droop setting as a "body roll stop".
Less droop helps in preventing traction rolls and adds stability on flat surfaces. It also quickens rotation. Think about doing the slalom course in an suv vs a sports car.
More droop adds traction to the outside wheels when cornering, but decreases stability on flat surfaces as it increases body roll. More droop also helps when landing from jumps and in rough sections of the track.
Like any tuning aid, it has to be used in conjunction with springs, ride height, etc, to get the suspension working in harmony.
Ridley is offline
Old 03-29-2011, 12:34 PM
  #5148
MONSTER JOE's Avatar
Originally Posted by Ripped
My losi with the novak 4.5 runs in the mid 120's geared with a 16t pinion and it rocks...
[IMG][/IMG]
What was the temp. outside ,the person in the back looks COLD.
MONSTER JOE is offline
Old 03-29-2011, 12:35 PM
  #5149
Thanks for the update!
snowboardgeek1 is offline
Old 03-29-2011, 12:38 PM
  #5150
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Ram4whldr
Does everyone's center diff outdrives seem to wobble more than expected?
That was the case in my car. Center diff wobbled significantly more than front or rear diff out of the box. Guessing this might also be the cause of why my center diff pins were more worn out than my front or rear diff pins.
SEF is offline
  #5151
Originally Posted by BashemSmashem
On a smooth track you wont need full suspension travel cause there wont be a bunch of ruts and bumps for the suspension too soak up , on a rougher track you want more suspension travel . Changing ride height only raises or lowers the CG and where the shocks stroke starts . Droop can also effect weight transfer .
Your correct except for one thing. If a track gets really blown out you still
want less droop so you can skip across the holes without fliping over or
catching ruts. Less droop is good for both smooth high traction & blown
out tracks...
Droop is something you must be testing at all times on different tracks in
different conditions so you know where you need to be come main time
when you can not test.
Different droop setings will work different for every driving style...Test,
test and more test every chance you get...
Chuck 21 is offline
Old 03-29-2011, 12:39 PM
  #5152
Ripped's Avatar
Trader Rating: 17 (100%+)
It was in the upper 40's....
Ripped is offline
Old 03-29-2011, 12:42 PM
  #5153
Benny 13's Avatar
I highly recommend for people to read the Hudy Suspension Book for RC. It will def give you a good feeling for how the suspension on RC works , what tweaks change what and what to expect from it.
As for the arms, curious as to where they are breaking? One of my LHS has them on the shelf if I need em
Benny 13 is offline
Old 03-29-2011, 12:59 PM
  #5154
Ripped's Avatar
You better get up there and get them while you can....
http://cgi.ebay.com/Team-Losi-1-10-T...item5adfb1073b
Ripped is offline
Old 03-29-2011, 01:04 PM
  #5155
LosiSuperTruck's Avatar
Trader Rating: 21 (100%+)
LOL, anyone crazy enough to pay that might as well buy a new truck for spares. I have bought an extra truck just for spares. Apparently I should part it out on ebay.
LosiSuperTruck is offline
Old 03-29-2011, 01:06 PM
  #5156
irocdave12's Avatar
Originally Posted by Casper
Is it bent or does it just wobble in the outdrive? Just curious. The drive shafts have been holding up fine so I dont' see it being an issue either way but just curious.
You can chalk me up as another owner with a un-used truck with the bent rear drive shaft. Its bent for sure with signficant run out not just a wobble in the drive cup. You can clearly see a high and low spot when you spin it. I too attempted to bend it back and improved it slightly but it seemed to not hold its straightness and was bowed again from just sitting the following day. Seems like its under pressure from either end and it bows in the middle. I hoping with some break in time it will be better if thats the cause.
irocdave12 is offline
Old 03-29-2011, 01:08 PM
  #5157
I already have Chris' pins and the outdrives still wobble much more than they have in my other cars.
Ram4whldr is offline
  #5158
SaladFork's Avatar
LOL I usually do the same... I have two of almost every part for the truck, I thought about doing the eBay thing but would feel like a prick charging 60 bones for arms lol.
SaladFork is offline
Old 03-29-2011, 01:15 PM
  #5159
Ripped's Avatar
How long did they take to arrive after shipped?
I am running the sc-10 diff pins for now, but would rather have his..
Mine where suppose to ship today..
Ripped is offline
Old 03-29-2011, 01:20 PM
  #5160
wow, i may have to put up my full set on ebay.. i'll be watching this auction at the end..
racerx711 is offline
