Like Tree9Likes
Old 01-29-2011, 09:15 PM
  #451
Trader Rating: 17 (100%+)
Originally Posted by SaladFork
Aerodynamics? In SC... You mean weight, or other factors that are not worked into the calculator. It's great, I appreciate having something to find my drive ratios. But its missing quite a bit of functions that go into calculating speed.
I meant aerodynamics. I am sure you know that aerodynamics play a part in top speed, even in a SC at 30MPH. As far as weight goes, I think they expect you to use common sense along with the results. I could punch in the numbers for a Micro-T brushless system in a FG Monster Truck and get some pretty neat results, but what do you think would happen if I actually tried it? As long as heat and available current are not an issue, then weight is not an issue.
If you are not seeing numbers reasonably close to what the calc. is suggesting, then you have either used inaccurate data or you have other issues with your car/truck/electronics/ability.
burnineyes is offline
Old 01-29-2011, 10:25 PM
  #452
i believe the biggest factor in speed calculators (other then weight and aerodynamics(if applicable)) that is missing, is parasitic loss. one truck/buggy's drivetrain efficiency is not anothers.
cranium13 is offline
Old 01-30-2011, 12:00 AM
  #453
Guest
Default speed control?
What speed control do I need and motor for the rig?????
LOSIRACER77 is offline
Old 01-30-2011, 12:16 AM
  #454
shanty140's Avatar
I am going to run a Mamba Max Pro. If you have the money a Tekin RX8 would probably be the best ESC but I think the MMP is the best in price to performance by far.
shanty140 is offline
Old 01-30-2011, 12:23 AM
  #455
CarlCrocco's Avatar
Trader Rating: 92 (100%+)
I'm going with the castle 3800kv and a Mamba Monster .
CarlCrocco is offline
Old 01-30-2011, 01:19 AM
  #456
Guest
Default diffs
Are the diffs the same as the 1/8 buggy??
Old 01-30-2011, 02:15 AM
  #457
neobart's Avatar
Nope, they're the same as the 10-T and 810.
neobart is offline
Old 01-30-2011, 06:38 AM
  #458
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Bondonutz
But I have to agree that other motors such as a 550 BL mill "might" be better due to the weight of the SCTE.
I have one coming via mail as I write this and look forward to testing it.
Originally Posted by KainK
Dont take this to serious I am just making a point. I have personally used the Castle SCT system, and it is a great system for a lighter truck. It will get this truck around the track, but you will burn it up trying to keep up with the 550s.
As I mentioned
Bondonutz is offline
Old 01-30-2011, 06:56 AM
  #459
8ight-e's Avatar
Trader Rating: 58 (100%+)
What in gods name are you guys doing to pop so many mmp's? Was it that one bad firmware version and you just got lucky?? I've got 4 mmp's and NONE have popped. They have been in only 1/10 vehicles, but that did include my hyper SC 4x4 before I sold it. I actually used both a mm and a mmp in the hyper w/o issues... I will say I mostly ran a medusa 4pole 50mm sensorless motor in it most of the time though.. those little motors are more than enough and little beasts..
8ight-e is offline
Old 01-30-2011, 09:05 AM
  #460
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Does anyone know what the kit diffs will b filled with and what the shock oil is
Blitzrockey is offline
Old 01-30-2011, 10:23 AM
  #461
jason07's Avatar
Originally Posted by xxxtruck
I will be ruinning Tekin RX8 and SC 4.5. I hearing 16-17 is going to be to high with the 40 spur should I get maybe a 13 pinion
I agree 100% on your combo. I have an RX8 in my eight-e and couldn't be happier!
jason07 is offline
Old 01-30-2011, 09:57 PM
  #462
The diffs will come filled with greese and the shocks will have 30wt oil in them.
I ran the tekin 4.5 tonight and ran a 15t pinion on it and it ran very cool, could have taken the 16t i normally run on my novak 4.5 no problem.
hacker07 is offline
Old 01-31-2011, 05:22 AM
  #463
any update on arrival? tomorrow is feb 1st!!
skyler hays is offline
Old 01-31-2011, 06:12 AM
  #464
gibsonk042000's Avatar
Trader Rating: 31 (100%+)
Default ESC
So I see that there is a big debate about this! I am not big on the ESC's but I was going to run a MM and a Epic 550 D3 4.5 motor. Would it be good or should I get something else? I run the MM 2200 in my 8ight-E with no problem just had to turn it down. LOL
Please only helpful reply's no kiddo remarks
Thanks all
I just seen were that team epic motor is Sensored so what would be the best motor to buy for this truck that would go good with the MM ESC
gibsonk042000 is offline
Old 01-31-2011, 08:15 AM
  #465
Barring any odd customs issues, we should have it in and shipping out to dealers before the end of February. (fingers crossed)
hacker07 is offline
